Idler Arm Replacement Problem
Old Oct 9, 2007 | 12:35 PM
traben27's Avatar
Very newbie question, but I'm fed up with trying to figure it out on my own...So I bent the crap out of my idler arm and went ahead and got one with lifetime warranty. Only problem is I can't get the stud out on the arm end. First the three bolts mounting it to the frame gave me a problem, but I got those eventually. I already checked out that link for "idler arm maintenance" and he used a pickle fork to pop the stud out. I tried that but can't get it to budge. Any other tricks or tips on how to get that thing out of there?
Old Oct 9, 2007 | 12:41 PM
DeathCougar's Avatar
Beat on the end of the center link with a BFH. The idler arm will pop free. DO NOT HIT THE ARM OR THREADS! Been using that trick for years to remove them here at work.
Old Oct 9, 2007 | 12:44 PM
traben27's Avatar
I'll try that and let you know how it works. Thanks. I didn't do it but what happens if you do hit the arm or threads? Just wondering...
Old Oct 9, 2007 | 01:01 PM
I suppose if you are replacing the whole thing, it wont really matter. But obviously hitting the threads or the arm will bend/casue damage so if you were planning on reusing parts, that would be a bad idea.
Old Oct 9, 2007 | 01:15 PM
traben27's Avatar
Thats what I figured...so where exactly am I hitting?
Old Oct 9, 2007 | 01:23 PM
MudHippy's Avatar
Here:
Works like a charm anywhere there's a tie-rod end.
Old Oct 9, 2007 | 01:24 PM
Originally Posted by MudHippy
Here:
Beat me to it. What he said!
Old Oct 9, 2007 | 02:08 PM
traben27's Avatar
I'm gonna have to quote mudhippy, that worked like a charm. thanks for the help. it's amazing how quickly things go once you get that out of the way.
Old Oct 9, 2007 | 02:21 PM
ks_yota's Avatar
when you replace an idler arm, must you also buy a bushing and put it on first? like from autozone, they have an idler arm and idler arm bushing, or is it just autozone?
Old Oct 9, 2007 | 02:28 PM
Four Runner's Avatar
Banned for being an asshat
IDea: Make sure when using the pickle fork, have the flat-side face up, and the wedge-side facing down. Also a light coat of oil helps a bit, so the fork will have an easier go at it. yeah, it does make a difference sometimes on how the tool is held, I don't know why.
**And yeah, get a BFH. If it still wont go, pick up some marvel's or WD-40 and coat the joint, and let it sit for a bit. If it's been in there for a bit, it'll take a bit to get it loose.
EDIT: Duh, is the front end jacked up or not? *Sometimes having it not jacked gives enough free travel to aid in removal also, kinda like a re-install on the diff control arm, sometimes it just "falls into place", know what I mean?
Old Oct 9, 2007 | 02:30 PM
The bushing is in case you want to just rebuild your old one, you don't get the same as far as warranty though.
Old Oct 9, 2007 | 02:36 PM
MudHippy's Avatar
They come with new bushings.
These are some manganese bronze idler arm bushings I purchased from CustomMachiningUSA.com if you were wanting to upgrade. I believe they fit 92-95 stock idler arms, not 100% sure.
Old Oct 11, 2007 | 06:41 PM
n4ynu1010's Avatar
MudHippy has all the cool trinkets
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
ptb12
Jul 5, 2015 01:49 PM
