Help with passenger side power window
Old Apr 26, 2018 | 10:07 AM
jcam6222's Avatar
Ok so Ive got power doors and none of the electric components to make them work, I could care less about the locks, but need to be able to get the windows down summer time is here! Somehow Ive manged to get the drivers side WIRED with a in line 15amp fuse its only ONE power wire to the harness coming out of the door and then ONE ground and it works good! Now for the PASSENGER-SIDE Ive not been able to make it work exactly like the driver side.However i can run one power wire to one of the terminals on the harness from the door while having another one terminal grounded and make it go DOWN but that SAME terminal wont power it back up SO i have to CONNECT the power wire TO ANOTHER TERMINAL TO POWER IT UP!!! ,,,,, CAN SOMEONE PLEASE GIVE ME SOME ADVICE ON HOW TO MAKE IT SO THAT ONE WIRE WILL DO BOTH UP AND DOWN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! THANKS ,, ANY HELP WILL BE APPRECIATED
Old Apr 26, 2018 | 10:29 AM
RAD4Runner's Avatar
What Escalade are we talking about here?
Pls see signature.
Old Apr 26, 2018 | 11:03 AM
jcam6222's Avatar
LMAO... Its a 1990 Toyota pickup
Old Apr 26, 2018 | 11:16 AM
RAD4Runner's Avatar
GOOD!^^^ LOL!
BUT you need to show diagram of how you did it. A picture paints a thousand words. Which wires? What color? Are those the wires to motor terminals?
Did you test the motor directly? It should have 2 terminals. Positive to one terminal and ground on the other will roll window up. Reverse connections and window will roll down.
Did you inspect the wires inside the flex harness between door and body?
Ideal is to restore to stock. I have FSM of 1990-1995 4Runner. Not sure if same as your pickup.
Old Apr 26, 2018 | 11:40 AM
scope103's Avatar
... Somehow Ive manged to get the drivers side WIRED with a in line 15amp fuse its only ONE power wire to the harness coming out of the door and then ONE ground and it works good! ...CAN SOMEONE PLEASE GIVE ME SOME ADVICE ON HOW TO MAKE IT SO THAT ONE WIRE WILL DO BOTH UP AND DOWN!...
No.
You can't move the window up AND down with one wire. As Rad4runner points out, you have a single DC motor. Reversing the connections (+/gnd) makes the motor run in the opposite direction. Disconnecting one of the connections makes it stop.
You can do it with two wires (+ and gnd) through a DPDT center-off switch to the motor terminals. That is (essentially) how the door switch works.
If you want to keep more of the stock components, here's the schematic: http://web.archive.org/web/201102052.../7powerwin.pdf
(The door lock control relay allows you to operate the windows for a few seconds after key-off.)
Old Apr 26, 2018 | 12:12 PM
jcam6222's Avatar
Ok I see I did find a Door control box
Originally Posted by scope103
No.
Old Apr 26, 2018 | 12:27 PM
jcam6222's Avatar
This is the connector coming out the door that I put a power wire and ground wire too make it fuction. The door is complete . So what y’all saying is that it would need another Switch? Lol..
Old Apr 26, 2018 | 01:37 PM
Co_94_PU's Avatar
What they said was to put the factory wiring in it...
You need to connect the (master control) left side to the (slave/passenger) right side.
Master pin seven to slave pin three.
Master pin ten to slave pin Two.
Master pin nine to slave this is power input, I believe on pin five.
You'll need to trace the wires from that door connection to the window switch to find out what goes where inside the passenger door.
Old Apr 28, 2018 | 03:53 PM
jcam6222's Avatar
Thanks everyone
gary96360
Jun 10, 2010 12:00 PM
gary96360
Feb 16, 2010 05:06 PM
squishy321
Sep 11, 2006 04:01 PM
ElwayLite
11
Dec 17, 2005 09:07 AM
