Help Identifying this connector
Old Apr 5, 2022 | 01:09 PM
Lynnvalleyyota's Avatar
Hi everyone, I’m just finishing up with redoing the head gaskets on my ‘93, and I’ve come down to this one last connection that I can’t for the life of me figure out where it connects. It comes off the same loom as the TPS and injector connectors. It’s a two wire with a green/blue line and a red/black line.
If anyone might be able to identify it would be super appreciated. Cheers!
Old Apr 5, 2022 | 01:21 PM
JoeS's Avatar
Is there a plug under the throttle body? Looked at 93 v-6 3.0L engine bay pics and that cable looks like it goes down under the throttle body. Maybe on the intake tube? It can be too far away as the cable it but so long. Good luck.
Old Apr 5, 2022 | 01:31 PM
Originally Posted by JoeS
Is there a plug under the throttle body? Looked at 93 v-6 3.0L engine bay pics and that cable looks like it goes down under the throttle body. it can be too far away as the cable it but so long. Good luck.
thanks Joe! That’s what I thought too but I can’t seem to find anything under there that it connects to. I may have to pull the throttle body to see if I missed something under there. Cheers!
Old Apr 5, 2022 | 01:57 PM
Edited to add description of the wire. If anyone might be able to check their rig when they have a second to see where this goes would be slick. If I can find someone out there with a second Gen I’ll ask if I can look.
Old Apr 5, 2022 | 03:05 PM
scope103's Avatar
Odd. It sure looks like the Knock Sensor PigTail-to-Harness connector. (EB1) Those wire colors should be Black and BRown.
The only GReen wire listed in my EWD is STJ to the Cold Start Injector. http://web.archive.org/web/201411140...ne/97colds.pdf The other lead to the CSI should be B-W.
EDIT: The ECT Sensor should have a connector very similar to the one in your
picture. Its leads should be G-L (Green-Blue) and BR-B (Brown-Black).
Old Apr 5, 2022 | 03:18 PM
JoeS's Avatar
It looks like it goes straight down towards the frame. O2 sensor connector?
Old Apr 5, 2022 | 04:00 PM
JoeS's Avatar
Good luck. Let us know what it connected to.
Old Apr 5, 2022 | 04:03 PM
whelp I feel like a complete moron and should probably sell my tools and take up knitting. So the temp sender connector had somehow gotten into the ECT connector, probably when I was plugging everything in, so it confused me as it looked like it was connected. Thanks a bunch for the help responses everyone, this is quite embarrassing.
Old Apr 5, 2022 | 04:22 PM
scope103's Avatar
Do check your wire colors. Take a picture and report back. Don't feel stupid; someone will find this thread someday and might want to know the wire colors, the shape of the connector, etc.
PS You might have to slightly wet (spit) the wire to get the wire color.
Old Apr 5, 2022 | 08:11 PM
yes my lighting threw me off and I kept mistaking the wire colours. It ended up being the ECT wire as mentioned by others, the temp sender single wire must’ve accidentally been pushed into the ECT sensor so it ‘appeared’ to be plugged in. But in reality it was just sitting there. This is a true facepalm moment 🤦🏻‍♂️
here’s a photo, so anyone reading this can have a laugh. This is what happens when you’re not paying close attention!
Old Apr 6, 2022 | 06:02 AM
scope103's Avatar
Originally Posted by Lynnvalleyyota
yes my lighting threw me off and I kept mistaking the wire colours. ...
So yours are G-L (Green-Blue) and BR-B (Brown-Black)?
Don't forget that this is all archeology; there's no guarantee that the EWD I have is accurate over all 2nd Gens. Or any of them. Or that the wire colors on my truck (I didn't actually check, of course) are the same as anyone else's. Your contribution (as embarrassing as it might or might not be) could help someone someday.
Old Apr 7, 2022 | 07:56 AM
yes that’s correct. I kept mistaking wire colours, at first I thought they were red-black and green. Then brown-black and green. Then finally saw the dusty blue stripe on the green. Feel like a dolt on this one 🤦🏻‍♂️ I hope to heck this helps someone in the future!
128keaton
Nov 30, 2021 06:06 AM
sam_KOR
Sep 19, 2016 05:16 PM
vikecowboy
Jan 15, 2016 09:02 AM
SLAYfriknBODIES
Dec 1, 2014 05:53 AM
alan fryar
Jul 19, 2008 02:08 PM
