Headlight issues
Headlight issues
Hey guys i just came from a small drive on the highway and noticed that my headlights weren't working anymore. No Hi-beams or Lo-beams, the indicator on the cluster wont even come on when flicking between the hi's and lo's. All other lights are working thought, sidemarkers, truck lights, signals, all but the main headlights. I checked the fuses and found none to be blown but i find it strange that the headlights worked yesterday and today there both dead? Could it be something else or only the blubs?
I highly doubt it's a blown bulb. Your talking 4 filaments that went out at the same time. I don't think so.
Try this:
30A Headlight Relay
Under where it says HEAD
Try this:
30A Headlight Relay
Yup. You should actually hear it click when turning on the headlights. If I am not mistaken it's just a 5 pin 30A relay. (take yours out to confirm though. But even if it does click, it still might not work. The fuses for them are split left to right not high and low. High, low and off is selected via the relay.
You can test it with a battery and a couple of alligator clips and wires. Relays are pretty simple devices.
Hey guys just bringing this post back up. I just replaced my headlight relay three times, checked my bulbs and they look fine, checked the fuses there fine. This isn't adding up. Everything should be down pact correct, all the lights work except the damn headlights hi beams and lo beams. Also the hi beam indicator doesn't come on either. If somebody could please figure this out for me it would be great. I'm starting to really hate being home by 5 PM. Could it be something to do with the cluster? I did replace the bulbs on the cluster maybe a few weeks before it all happened
I really don't know, i'd like to say no because the rest of the lights come on. The cluster lights come on, the heater light comes on. Of course my problem is one that nobody has ever encountered. I just find it strange that the hi beam indicator doesn't come on, like theres no power there or something.
1)If you're getting voltage to headlight fuses and relay, and
2)That dimmer combo switch contacts have continuity to ground.
Fuses and relay supply positive side of bulbs (both low and high filaments), and dimmer switch provides ground to high beam or low beam whichever is selected. Absence of (1) or (2) would cause problem where both beams don't work.
Got a schematic and voltmete so we see details of your circuit? Then we'll go from there.
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
