Headlight issues
Old Jan 28, 2012 | 02:44 PM
Markarino's Avatar
Headlight issues
Hey guys i just came from a small drive on the highway and noticed that my headlights weren't working anymore. No Hi-beams or Lo-beams, the indicator on the cluster wont even come on when flicking between the hi's and lo's. All other lights are working thought, sidemarkers, truck lights, signals, all but the main headlights. I checked the fuses and found none to be blown but i find it strange that the headlights worked yesterday and today there both dead? Could it be something else or only the blubs?
Old Jan 28, 2012 | 02:46 PM
peow130's Avatar
Did you try a spare bulb?
Do you have a test light? See if you get conductivity between the posts to ground on the lights.
Old Jan 28, 2012 | 02:47 PM
xxxtreme22r's Avatar
I highly doubt it's a blown bulb. Your talking 4 filaments that went out at the same time. I don't think so.
Try this:
30A Headlight Relay
Under where it says HEAD
Old Jan 28, 2012 | 02:53 PM
Markarino's Avatar
Try this:
30A Headlight Relay
I forgot to mention that i have a 1989 toyota pickup, i dont think i have a fuse box like that
Old Jan 28, 2012 | 02:56 PM
Newer one still says HEAD.
Old Jan 28, 2012 | 03:02 PM
Markarino's Avatar
Oh thanks, the problem with mine is the the paper thats on the top of the fuse box is covered in oil so i can't actually see whats what. So your saying i should just replace the relay?
Old Jan 28, 2012 | 03:08 PM
Yup. You should actually hear it click when turning on the headlights. If I am not mistaken it's just a 5 pin 30A relay. (take yours out to confirm though. But even if it does click, it still might not work. The fuses for them are split left to right not high and low. High, low and off is selected via the relay.
Old Jan 28, 2012 | 03:10 PM
Markarino's Avatar
It doesn't click at all, i use to hear the noise when i would flicker the highbeams
That's most likely your problem then.
Old Jan 28, 2012 | 03:11 PM
jonnydclark's Avatar
You can test it with a battery and a couple of alligator clips and wires. Relays are pretty simple devices.
Old Jan 28, 2012 | 03:12 PM
Markarino's Avatar
Thanks for the quick reply. I would go get another relay right now if i could but its already dark out. Last thing i need is a ticket. I'll let you know if that solves my issue. Much respect.
Old Feb 8, 2012 | 02:33 PM
Markarino's Avatar
Hey guys just bringing this post back up. I just replaced my headlight relay three times, checked my bulbs and they look fine, checked the fuses there fine. This isn't adding up. Everything should be down pact correct, all the lights work except the damn headlights hi beams and lo beams. Also the hi beam indicator doesn't come on either. If somebody could please figure this out for me it would be great. I'm starting to really hate being home by 5 PM. Could it be something to do with the cluster? I did replace the bulbs on the cluster maybe a few weeks before it all happened
Old Feb 8, 2012 | 03:39 PM
angrybob's Avatar
Heh - I would start here.
Work through that first. It may fix this problem.
Old Feb 8, 2012 | 05:15 PM
Markarino's Avatar
Already fixed that, just did it a few hours ago. Hasn't fixed anything.
Old Feb 8, 2012 | 05:24 PM
Combo switch maybe?
Old Feb 8, 2012 | 05:32 PM
Markarino's Avatar
Combo switch maybe?
I really don't know, i'd like to say no because the rest of the lights come on. The cluster lights come on, the heater light comes on. Of course my problem is one that nobody has ever encountered. I just find it strange that the hi beam indicator doesn't come on, like theres no power there or something.
Old Feb 8, 2012 | 07:43 PM
falcon5nz's Avatar
Try this
Old Jan 3, 2014 | 08:04 AM
DubbleJ's's Avatar
Bumping an old thread because im having the exact same issue on my '96 Tacoma... No high or low beams. I tried new headlight bulbs and relays, checked fuses too.
Did you ever figure this out??
Old Jan 3, 2014 | 09:39 PM
RAD4Runner's Avatar
Gotta check:
1)If you're getting voltage to headlight fuses and relay, and
2)That dimmer combo switch contacts have continuity to ground.
Fuses and relay supply positive side of bulbs (both low and high filaments), and dimmer switch provides ground to high beam or low beam whichever is selected. Absence of (1) or (2) would cause problem where both beams don't work.
Got a schematic and voltmete so we see details of your circuit? Then we'll go from there.
ghostmoney
Jan 28, 2018 11:42 AM
Sep 4, 2015 09:27 AM
mldave
Aug 10, 2015 09:23 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
