going to replace head gasket
So I am going to replace my HG on the 89runner 22-re.IT was done recently by the previous owner. He had the head machined and put he new HG in himself.Now it is blowing white smoke and losing coolant after only less than 1 year of use.What would cause the hg to go again and what things are important to do so this doesn't happen again.Thanks.
if he used a generic felpro type head gasket, it could be just bad luck. these gaskets don't work well on our engines unless the finish on both the block and head are perfect. toyota's gaskets(as well as rock and some others) employ a steel slip plate on the head side that allows the head to expand freely without harming the gasket. much more forgiving, if a couple bucks more.
i misunderstood the toyota parts person they are actually between $10 and $14 dollars a piece so i called around and was unsuccessful finding anything cheaper.however engnbldr sells a headgasket set with the bolts for $60 u.s. still cheaper then toyota.i am going to contact engnbldr today to see if i can just order the headbolts.the ram is a unbelievable river i caught my first cutt there i also purchased my 86 runner to bush bash on the ftr and your right go oilers go.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jnkml
Jul 6, 2015 01:20 PM
