going to replace head gasket
Old 06-15-2006, 12:10 PM
hirsche23's Avatar
So I am going to replace my HG on the 89runner 22-re.IT was done recently by the previous owner. He had the head machined and put he new HG in himself.Now it is blowing white smoke and losing coolant after only less than 1 year of use.What would cause the hg to go again and what things are important to do so this doesn't happen again.Thanks.
Old 06-16-2006, 07:38 PM
Elton's Avatar
there alot of things that can cause a hg to blow
Old 06-17-2006, 02:01 AM
kyle_22r's Avatar
if he used a generic felpro type head gasket, it could be just bad luck. these gaskets don't work well on our engines unless the finish on both the block and head are perfect. toyota's gaskets(as well as rock and some others) employ a steel slip plate on the head side that allows the head to expand freely without harming the gasket. much more forgiving, if a couple bucks more.
Old 06-17-2006, 07:23 AM
clint's Avatar
he might noy of replaced the 10 head bolts,in which i have read that they are not reusable something to do with the stretching of the metal i think, you can pick them up from toyota for $15.
Old 06-17-2006, 01:16 PM
hirsche23's Avatar
I know he reused the head bolts(crap) and did get the head machined,so I am going to get the hg from toyota as well as new bolts and hope that it solves it.
Old 06-17-2006, 07:59 PM
kyle_22r's Avatar
the head bolts are reusable on a 22R engine, but i definitely wouldn't hesitate to replace them if they were pitted or in bad shape otherwise.
Old 06-17-2006, 08:42 PM
Elton's Avatar
just get all your stuff From engnbldr
Old 06-19-2006, 11:57 AM
clint's Avatar
i misunderstood the toyota parts person they are actually between $10 and $14 dollars a piece so i called around and was unsuccessful finding anything cheaper.however engnbldr sells a headgasket set with the bolts for $60 u.s. still cheaper then toyota.i am going to contact engnbldr today to see if i can just order the headbolts.the ram is a unbelievable river i caught my first cutt there i also purchased my 86 runner to bush bash on the ftr and your right go oilers go.
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
Whatever123
09-30-2015 12:12 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: going to replace head gasket
