Old Mar 30, 2016, 09:09 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Specifications & General Maintenance
Print Wikipost
Fuse box photos??
Old Aug 1, 2010 | 02:37 PM
mldave's Avatar
Fuse box photos??
Any one have good photos of the two fuse boxes on the 86 Toyota 4x4 truck w/the 2.4 EFI?
Old Aug 1, 2010 | 02:50 PM
myyota's Avatar
What are you looking for, or trying to do ?.
scuba's Avatar
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Aug 1, 2010 | 02:51 PM
4Crawler's Avatar
Here is some '85 fuse box info:
http://www.4crawler.com/4x4/4R_TechI...tml#Electrical
Old Aug 2, 2010 | 10:01 AM
mldave's Avatar
Myyota,no power at dome light switch..fuse good.Cleaned door plungers and switch housing.Not grounded somewhere? Where abouts would the ground be.Trouble is I'm not mechanical and my hands are shot from pinched elbow nerves.
Old Aug 2, 2010 | 10:12 AM
dropzone's Avatar
Fossilized
check your connections...24 year old truck, thinks come loose
Old Aug 2, 2010 | 10:26 AM
dhall50's Avatar
My 86 had the same prob. It was the switch and connections in the dome its self. I had to push things around etc and blamo let there be light. Funny because this way like a week or two ago.
Old Aug 2, 2010 | 11:02 AM
MudHippy's Avatar
It took me awhile to find the thread it's in. I knew I remembered seeing it here before somewhere.
86-88 inside fuse diagram thread
Old Aug 2, 2010 | 02:08 PM
mldave's Avatar
Thanks Man....still no juice at the dome light.
Old Aug 2, 2010 | 02:13 PM
4Crawler's Avatar
The door pin switches are what grounds the dome light. Should have constant 12 volt and then either the door switch or the switch on the dome light itself supplies the ground.
Old Aug 2, 2010 | 02:35 PM
mldave's Avatar
Will take out the switch and look at the back of it at some point.Also will remove the kick panels to see if I can access the plungers.This truck has had wiring problems as a new engine was installed and perhaps wiring diagrams were not followed.Anyone know the part # of the cold start injector time switch?The chilton manual I have has such small print on the diagrams I can't read it,besides my hands being shot from pinched nerves in the elbows.So often I have to wait and find help on repair issues.Can't really afford the shops as they're $95-$110 an hour in the California motherlode.Talk about a gold rush...Thanks for the replies.
Old Apr 4, 2012 | 06:28 PM
hiddenreecse's Avatar
thanks for the pic.
Old Aug 24, 2013 | 09:01 AM
Buck87's Avatar
Smile
Thread revival...Thanks for the photo.
Old Jan 20, 2023 | 02:20 PM
bsinger4's Avatar
Power to the Main fuse panel 84 4x4
Does anyone know what color the primary power wire for the cabin fuse panel in an 84 Toyota
4x4
sniper34639
Aug 31, 2015 07:56 AM
bvleonov
Aug 22, 2015 11:39 PM
Mrhoadley
Aug 4, 2015 06:08 PM
itzmywife's
Jul 23, 2015 08:32 AM
rushw
Jul 18, 2015 01:46 PM
