broke my timing chain guide, time to rebuild (pics)
Old Apr 26, 2011 | 09:27 AM
  #301
Lumpy's Avatar
Sounds like a nice short list. I want to hear it running by 5:00!!!
Old Apr 26, 2011 | 02:20 PM
  #302
irab88's Avatar
problem: one or more of the cold start injector washers or bolt is bad. it looks like an old faithful of fuel in my engine bay. i'll also need to re-paint my intake chamber
Old Apr 26, 2011 | 02:22 PM
  #303
92 TOY's Avatar
Ian....i had alot of trouble getting that on. did you use new washers? i did not torque (don't know if there is a torque value for those or not)....be careful now!
Old Apr 26, 2011 | 02:25 PM
  #304
92 TOY's Avatar
see if this post helps
https://www.yotatech.com/forums/f116...l#post51463795
Old Apr 26, 2011 | 02:27 PM
  #305
irab88's Avatar
not new washers, but i will be now. i'll see if the parts store has them after dinner. it makes sense if they're copper crush-type washers. boulder dam
Old Apr 26, 2011 | 02:28 PM
  #306
92 TOY's Avatar
did you have trouble threading them like i did. that's what i meant in that post.
Old Apr 26, 2011 | 02:29 PM
  #307
irab88's Avatar
Originally Posted by 92 TOY
how did i miss this... grrrrr!
where did you get your washers?
Old Apr 26, 2011 | 02:32 PM
  #308
irab88's Avatar
nope. it was snug, but it fit just fine. it's the washer issue that got me
Old Apr 26, 2011 | 02:39 PM
  #309
RBX's Avatar
RBX
Take the washers you have and lay a piece of sand paper(fine grit) on the flattest surface you can find and rub the washers on it until all the grooves in the washer are gone. I called and left you a message.
Old Apr 26, 2011 | 03:02 PM
  #310
92 TOY's Avatar
TOYOTA........cheap......order extras......i dropped a few before i put a "net" under the area.
i don't recall actually, but i believe (and I could be VERY wrong) they are ??hollow??......well, whatever.....i think they are like 79cents apiece.
Old Apr 26, 2011 | 04:32 PM
  #311
irab88's Avatar
it runs. and it runs well. i have a temporary fix on the cold start injectors, but those will vanish soon enough. i'll do timing tomorrow, along with burping the radiator.
now for a spin around the block!
Old Apr 26, 2011 | 05:15 PM
  #312
92 TOY's Avatar
well......in that case...... WAHOOOOOOOOO
Old Apr 26, 2011 | 05:24 PM
  #313
irab88's Avatar
aaand just got back from a li'l test run. runs fine with a few stutters (very few). also, i was waiting at a light, and the idle dropped to a tad below 500. i had to tap the gas to keep from stalling out, but after i turned around to head back, it was fine. huh, any ideas? i'm about to call it quits for the night, but i'll be back at it tomorrow
Old Apr 26, 2011 | 05:25 PM
  #314
92 TOY's Avatar
if you didn't set the timing yet....maybe it's that
Old Apr 26, 2011 | 05:40 PM
  #315
irab88's Avatar
probably. thanks.
now for some pics! (no labels as it's late and i'm tired. i'll put them on later)
Old Apr 26, 2011 | 07:26 PM
  #316
ChefYota4x4's Avatar
Man, it must have been great to pull outta there running, eh? WOOT! Great job, man!
Far as the crush washers, ....one of them is copper and one is soft steel/tin/aluminum? hahaa. It's silver, I'll just say that. Far as my leaks, it was my damper. I did what RBX said and voila! Just used some emery actually, ...wasn't bad with impression, etc., so it worked fine. However, ...the CSI ones?/Yeah, I'd just get it, I did, and they were like 4$ each. The one with the tongue on it is a lil more, but both are like 7$ I think? With those fresh clean things in there, why not use new ones, eh? lol. (HOWEVER< ....that method probably would work fine on those, as well )
Have a nice night sleep, man, ...bet you're wiped out, eh?
PS> LOOKS GREAT, ..like that color scheme, ..it's AGGRESSIVE! grrr, lol.
Old Apr 27, 2011 | 01:50 AM
  #317
92 TOY's Avatar
like the empty bay pic.....I did the same thing.
good job bud.
Old Apr 27, 2011 | 04:22 AM
  #318
RBX's Avatar
RBX
Ian, your stutters could be the computer relearning a fuel map. If the ECM is unplugged for a while, the computer resets and returns to the base-map, then relearns as you drive more and more. And if the timing isn't set correctly, it may have a more difficult time learning.
Set your timing up, and reset the ECM(pull the fuse), then take her for a spin. Let her warm up good, then give her a good flogging. Make a few good shakedown runs, if something is going to break you want it to happen now....my guess is...nothing will break.
I also want to hear how those injectors feel now that they are balanced.
Old Apr 27, 2011 | 04:41 AM
  #319
S.Skinner's Avatar
Congrats man, glad you got her done!!! Looks good. I'm at a stand still till i get some cash. Heads and block are done and awaiting p/u. Just waiting on some funds to clear. Have the rebuild kit on hand so its just a waiting game....
Old Apr 27, 2011 | 06:18 AM
  #320
irab88's Avatar
thanks mark. yeah, it's nice to know i have nothing left to do (or very little). it rides a lot higher than i remember, but then again, i have been driving an a55-dragger of a car (it's a nice little car, though it is tiny)
good job bud.
thanks. now i have to clean it up
ah-ha! i'm sure it'll get better once i do the timing, but that would make sense. thanks
so far, in between stutters, the engine runs smooth. and if the 22r-e wasn't famous for it's loud valve tap, i would call it quiet.
hang in there bud. take your time, take lots of pictures for personal reference, read the service manual, and take your time. yeah, i said it twice.
thank you to everyone who helped out (92, mark, brandon, peow, lumpy, rb, and the list goes on...)
i could not have done this as easily as i did were it not for your continued wealth of knowledge. it feels good knowing that i can now do any repair to the engine. take that, dealership! thank you all so much
