Another 88 rebuild/questions thread (in Hawaii)
Old Mar 24, 2010 | 04:48 PM
  #121
rogerman's Avatar
haha ok. they are so hard to remove! I have no leverage
Old Mar 24, 2010 | 04:51 PM
  #122
92 TOY's Avatar
PB BLaster.............let them sit.
can you raise the diff??
I am running out of available time here.......raise and support that diff , it's probably making things bind.
Old Mar 24, 2010 | 04:52 PM
  #123
rogerman's Avatar
ok I'll be blast them now and let em sit. yes I can raise the diff. Thanks 92!
Old Mar 24, 2010 | 04:57 PM
  #124
92 TOY's Avatar
gotta go....I'll check back in in a little bit....it's the end of the day routine here....round up 2 kids etc.....
Old Mar 24, 2010 | 06:43 PM
  #125
rogerman's Avatar
So my goals went to hell today. The 4 17mm bolts that secure the front diff crossmember are an absolute pain in the @ss! I'm gonna wait for my cousin to give me a lift to sears to get a couple 17 mm wrenches.
All I got accomplised today was:
- Unbolt oil pan and pickup
-Get timing cover off
-clean timing cover surface with many razor blades.
Side note:
I was pretty thrilled when the crank pulley slid off. that was pretty nice after that it turned ugly.
Hopefully the bolts will be easier to remove after a night of pb blastin and some new 17mm wrenches.
Goals for tomorrow:
- Get front diff cross member off.
-remove and clean oil pan.
- start the reassembly of timing components.
I really gotta get this all buttoned up by this sunday and the aboslute latest is before my dad comes to visit april 10th! God grant me speed.
Old Mar 24, 2010 | 06:59 PM
  #126
yotarob2005's Avatar
good luck man, you are on the right track
Old Mar 24, 2010 | 07:20 PM
  #127
Lumpy's Avatar
Ok Catchin up a bit
Originally Posted by rogerman
Good point. So the general consensus is using gasket remover, razor blades, what else works? I have a feeling I'm going to spend a small fortune on cleaning products
Razor blades work really well I use them as well. Make sure you get the older for them it will make all the difference. When you get to the aluminum parts take heed. The aluminum is soft and it is possible to get bad groves real quick. Keep it flat and take your time use a bunch of break cleaner to get the old gasket material soft.
Just spent a fortune at walmart tonight
-Brake Cleaner
-Red high temp rtv/gasket maker
-blue locktite
-brake fluid
-simple green
-castrol gtx High mileage 10w40
-other small things like fusion paint, shop towels, lube.
still need to get
-Black FIPG
-Oil Filter
-Breaker bar (what length?)
-1/2 socket for crank
-small floor jack
-small kine stuff like cheater pipe and 2x4s
Am I missing anything?
Seem like a good list but I'd stay away from the Locktite! I didn't use any RVT on the intake gaskets at all. I'd only use it where the FSM says to use it. Now some folks will use a "very light" film on the paper gaskets. I didn't need to use any. Now I didn't pull the timing cover or the pan, just the heat and the manifolds were completely out.
Oh boy just spent another small fortune tonight.
-1/2" 19mm shallow socket (regular, didn't have impact)
- Brake bleed cup thing
- Feeler gauge for rocker arms
- Fiberglass hammer
- 2 ton floor jack (cheap walmart one)
- more pb blaster
- Black gasket maker ( Idk if toyota here has it and I don't feel like spending more $$)
- copper spray a gasket (saw my cousin use it when we rebuilt my 92)
I think all I need now is an oil filter, snow pec, 2x4, cheater bar and I think I'm pretty much set..
Side note: Can you believe they want 20.99 for a 10mm/12.mm Flare nut wrench at sears?! holy hell I blurted out and the stocker started laughing.
I would not use anything on the HG I know some folks like to use it but I wouldn't. I like the smell of PB Blaster!!!
Ok now to keep on reading...Nice little project here.
Old Mar 24, 2010 | 07:35 PM
  #128
Lumpy's Avatar
Ok all caught up now...Your doing quite well keep it up!!!
Old Mar 25, 2010 | 02:55 AM
  #129
rogerman's Avatar
Thanks lumpy. I just gotta get the crossmember off! It would be nice to use like a cordless impact wrench to get it off. I saw one at sears for like 100 bucks. rated at 200ft/lbs of torque. Getting that could potentially speed things up. That would be sweet. haha!
Question to all:
- What should I do next? After I finally get the pan off and cleaned?
if you were in my shoes what would be your next course of action or courses?
Heres the badboy I was talking about:
http://www.sears.com/shc/s/p_10153_12605_00917090000P
Old Mar 25, 2010 | 03:14 AM
  #130
92 TOY's Avatar
Question to all:
I'd hesitate on power tools.....I didn't need them....like to be able to feel what's happening....i really don't think you need it.
let me look at those bolts a little, i was just doing some research to identify a part for YOTAROB.....searching my pics. but i do have those bolts in a box ...I really didn't have that much trouble with them.
as far as what's next?.......with the pan off, you have some serious cleaning to do...of the pan, the oil strainer and tube and have to start thinking about going in reverse order now.
get your timing cover assembled and ready to go....your head is off, get your timing chain parts ready to go and possibly installed....that's where i am at.
Old Mar 25, 2010 | 03:16 AM
  #131
92 TOY's Avatar
were you able to jack the diff up at all??
Old Mar 25, 2010 | 03:20 AM
  #132
92 TOY's Avatar
yes, you need a 17mm socket and I assume a corresponding 17mm wrench for the other side (nut).....these bolts are about 3'' or so long, with about only 1'' of thread.
Old Mar 25, 2010 | 12:10 PM
  #133
rogerman's Avatar
I can get my diff high enough to hit the pan. I'm not sure why my bolts are so difficult. I know when I get down there I can't break them loose even with a cheater bar.
Old Mar 25, 2010 | 12:11 PM
  #134
Lumpy's Avatar
Sometimes you gotta grunt a bit to get them to break.
Old Mar 25, 2010 | 12:15 PM
  #135
92 TOY's Avatar
OK...we'll be right over....LUMPY, I'll pick ya up in 10 minutes.
there are little holes on top of that crossmember.......I think...i will check for sure.....you can probably spray PB Blaster at the inside of the bolts from there......that's my only other idea....that and eat a steak and potatoes dinner
Old Mar 25, 2010 | 12:16 PM
  #136
92 TOY's Avatar
here's a silly idea......put the socket on the NUT side, not the BOLT HEAD side........hopefully that's a help.
Old Mar 25, 2010 | 12:17 PM
  #137
rogerman's Avatar
that's a good idea. I'll try that. Did you just wrench away and they came out?
Old Mar 25, 2010 | 12:21 PM
  #138
92 TOY's Avatar
I believe that will likely be your solution....or did you mean the steak?
put a wrench on the head of the bolt because it will eventually want to spin too.
Old Mar 25, 2010 | 12:28 PM
  #139
Lumpy's Avatar
Always when you can turn the nut not the bolt...they will turn much easier. Good call 92.
See you in 10!!!
Old Mar 25, 2010 | 12:34 PM
  #140
rogerman's Avatar
Man right now I really wish I was in the states! haha! ohh boy well none of my friends are texting back so that means I might have to walk to sears... thats like a 30-40 min walk.. maybe a vice grips will work..
