Another 88 rebuild/questions thread (in Hawaii)
Old Mar 25, 2010 | 08:21 PM
  #161
rogerman's Avatar
To hoist the the head with intake manifold up while I thread all the hoses and wires through the lower manifold. It's heavy and I don't wanna ruin a new headgasket.
Old Mar 26, 2010 | 01:30 AM
  #162
92 TOY's Avatar
good job....
Old Mar 26, 2010 | 03:18 AM
  #163
rogerman's Avatar
I feel like I deserve a medal haha!
Old Mar 26, 2010 | 03:53 AM
  #164
rogerman's Avatar
Question:
-What gaskets go on dry?
-What gaskets go on with rtv/gasketmaker?
Old Mar 26, 2010 | 06:22 AM
  #165
Lumpy's Avatar
I didn't use RTV at all when I did my HG...Mind you I didn't pull the timing cover or drop the pan. I did however have the intake apart and the exhaust apart and I didn't use any RTV on the paper gaskets at all. No leaks so far it's been a year.
Old Mar 26, 2010 | 06:38 AM
  #166
yotarob2005's Avatar
Originally Posted by rogerman
Oh question to all:
How do you prime the oil pump? Does it need to be done? When I rebuilt my 92 with my cousin he didn't prime it, he just ran the starter for a little bit.
Pack the gears of the oil pump with either Vasoline & sta-lube marine grease. Also run the starter for a short bit.
Old Mar 26, 2010 | 06:40 AM
  #167
Question:
I used very light RTV on the water pump only all of the rest went on dry, I can't say it doesn't leak because it still doesn't even run
Old Mar 26, 2010 | 07:18 AM
  #168
92 TOY's Avatar
I used a spot of stuff to hold the timing gaskets in place......no leaks so far. Oh wait.........
Old Mar 26, 2010 | 07:19 AM
  #169
92 TOY's Avatar
I told you it was because you had an easy time with the crankshaft bolt......hahahaha..
I have to go back and re-read everything you did....tight on time today.
Old Mar 26, 2010 | 09:21 AM
  #170
92 TOY's Avatar
Holy crap....
1st of all I guess that those 2 pictures are officially the Hawaiian-1-finger-salute.
2nd:on your little suggestion of using 2 people, is better to be the one swinging the hammer, than holding the wrench.
3rd: your picture of the back of the timing cover answered my question about if the passenger's side water pipe gets a gasket...yes it does, i see it in your pic.
4th: Timing cover or head 1st? FSM shows timing cover....I'm going by that. there are some key areas you need to put FIPG where the head mates with the cover and it's a sloppy unreliable mess (my opinion) doing the head 1st and smooshing the timing cover in there.....I don't know, I may change my tune when I get that far.
5th: vaseline is what i packed the oil pump with.
6th: a hoist? really? I stood on an 8'' high little platform I had laying around and took the hood latch square to the belly....hurt for days.....you gotta take your lumps....maybe that hoist explains why you had so much trouble.
7th: you gotta get that thing off the hoist to clean you head.
8th: GREAT JOB!
Old Mar 26, 2010 | 09:24 AM
  #171
92 TOY's Avatar
Oh and point #9....did you follow my instructions?????? Hmmmmmmmm??? on the https://www.yotatech.com/forums/f116...re-4wd-206089/ thread??? hmmmmmmm????
did i say to loosen the crossmember 1st? did I?? did I?? because if I didn't I will go back and edit it......
you're just lucky the WABBIT didn't come in here and tell you to hit those bolts with your purse.
Great Job again man!!
Old Mar 26, 2010 | 09:25 AM
  #172
92 TOY's Avatar
does the passenger's side water pipe have a gasket too??? couldn't find one that fit exactly right.
Old Mar 26, 2010 | 01:46 PM
  #173
rogerman's Avatar
Haha you guys are a trip! Everyone is giving me a hard time about the hoist. I couldn't remove my lower intake manifold so I had to thread ALL the wires through it. It was an absolute pain putting the crap through but imagine trying to preserve a new headgasket while pulling all the wires through it.
Old Mar 26, 2010 | 01:49 PM
  #174
rogerman's Avatar
Or maybe there is misunderstanding? I got the head off without the hoist... Nvm I'll just take pictures of what I'm doing. Gonna start soon.
Old Mar 26, 2010 | 02:03 PM
  #175
92 TOY's Avatar
too late for pics...we all know what you did....hahahahhaha
Old Mar 26, 2010 | 05:09 PM
  #176
rogerman's Avatar
So I'm putting the timing components back on and I'm at a crossroad, Do I put the head on or the timing cover? If I put the head on first I'll be able to keep the tensioner compressed but if I put the cover on first I wont be able to compress the tensioner. What have you guys done?
Old Mar 26, 2010 | 05:25 PM
  #177
rogerman's Avatar
Looks like I hit another snag and I might have to use my old timing cover... I didn't notice but there are some threaded studs that are on the old timing cover but not the new one :\ Is this normal for all engnbldr covers?
Old cover with a total of 3 studs
New cover without any studs:
Should I just reuse my old cover? It has grooves but they didn't eat through all the way. or???
Old Mar 26, 2010 | 05:39 PM
  #178
rogerman's Avatar
they are for the water pump btw
Old Mar 26, 2010 | 05:45 PM
  #179
92 TOY's Avatar
those come out.....carefully...put some PB blaster on them and use a very gentle twist with small vice grips on the non-threaded areas.
those have to be re-used.....just un-messed that little screw-up on mine...the studs TED includes are for your fan (4 studs...mount on the front of the water pump where the fan clutch attaches)
Old Mar 26, 2010 | 05:46 PM
  #180
92 TOY's Avatar
I already chimed in on that, but I am equally concerned like you are.
