90 Sr5 Rebuild Paint Everything! PICS
#82
Cold air = you suck in hot engine bay air with a "free flow" filter, that will actually let more dirt into your engine.
ISR = You use the stock airbox which gets cold outside air from behind the headlight, and you can use your stock paper filter for great filtration, or swap it out for a "free flow"..
NOT MUCH is different. The cost is the best thing = under $30
#83
what kind of gun did you use to do your paint job. iv pained several vehicals and have a nice compressor and hvlp gun but not a proper air dryer system, basicly i crack the drain cock on the bottom of the compressor and run multiple disposable air dryers i can go threw 15 disposable air dryers on a paint job to get a nice paint job. for the nice air dryer systems your looking at a pretty penny i don't paint enough vehicals to make it worth it. iv also heard of people using airless paint sprayers, im just curious what you used
#85
Man i update this thing every day it seems like!
lol this weekend should be alot tho. my gaskit kit and rod and mains should be here by friday and if the machine shop is quick then ill have it to finish up Saturday or sunday at the latest monday!! thanks for keepin on me tho! later
Id really like some jager Bombs right now i think everyone should take a shot and sit by a bon fire its cold and thats what needs to be done.!
#86
#89
Update 10/31
Everything is on schedule got all the new parts in yesterday delivered everything the the machine shop last night hopefully he finishes it up today or tomorrow if i get the bottom end back from him by Saturday i should have it in on Sunday!!! hope hope hope...
How much you think i could sell this truck for back in florida? just wondering what yall have seen price wise..
#90
Builds Back On Update 11/06
Ok so i got my motor back from the machine shop tonight so im back on the build! i paid him to short block it for me so im a few steps ahead and looking good.
Ill start with the receipt, it doesn't include him short blocking it for me I paid 421$ total...
Then a little head cleaning. How bad is it to clean your head with engine degreaser?
Then some new parts gaskit kit and new oil pump...
Then just pics of the done deal..
then ill add one or 2 more personal pics got me a deer with a 22mag right out the shop door 2 nights ago while cleaning my heads up...
Field i got him in he was a little spike.
#94
#96
I have pictures of all of it but the internets moving so slow i cant upload them tonight so ill have to do it in the morning. basically it looks like a half moon its about 3/4 of an inch long bout a 1/4 wide and 1/2 deep.. its semi press fitted into the crank right in front of the oil pump your timeing gear slips on it and so does the main crank pully it holds eveything in order and keeps everything on time..... if you still dont get it i have pictures for tomarow. good night yall
#97
#99
Alright NOW my internet is not being so stupid! so ill start with the key way and my problem!!!!
With NO key in...
How it normally sits and the side i chipped off.....
Hard to see but have it in backwords and it would work but im not so sure on that one....
Another angle maby you can get a better view
OK SO THE NEXT PROBLEM... me being me didn't order a water pump so the circled part fell out today while installing the water pump i have resting back in there but dont know if i need a new one now... there is nothing that hold it in -I.e bolts nuts ect. it looks like it might be some sort of press fitted looks like a bypass or something ANY HELP!!!!
Got a cupple crap pics of what i accomplished today
And a better idea of how the heads turned out!!!!
So if you cant tell today i got the rear main seal swapped out and put on, got the oil pump on(ITM does not send you an oil pump gaskit!!! NOT EVEN WHEN YOU ORDER AN OIL PUMP! have to use RTV.....), got the water pump on but broke the hose intake thing, broke the key way and took a trip to the dealership!
, started cleaning off the old gaskit from the oil pan(no pics) and cleaned the heads a little more(herd it was REAL important to get then clean) also if you can see in the pics i filed down and smoothed where the washer dented up the heads didn't turn out to bad will work just fine!
