90 Sr5 Rebuild Paint Everything! PICS
Old Nov 8, 2008 | 06:21 PM
  #101
YoterUp's Avatar
com on guys nothing its been all day and no one says anything.. guess no one knows huh>? thanks anyways!
Old Nov 9, 2008 | 03:28 PM
  #102
YoterUp's Avatar
Talking Update 11/9
Got some more stuff done today not alot it was snowing all day and extremely cold! i did what i could with no heat but im not in much of a hurry i dont get my keyway till tuesday, if nothing goes wrong im hopeing to have eveything done by friday and then ill be able to do final tests and things this weekend and take my trip back to florida first thing next week!! some new pics
Woke up to some snowing this morning! So i watched me some sunday football!
Then started with the oil pan shows after i cleaned off the old gaskit and put the new one on.
After i got my heads on still not torqued on just sitting there with the gaskit on ill finish that up tomorrow and then clean up the rest of the head ill probable do the intake tomorrow and the exhaust manifold
Its cold some snow as i came in from the barn!
Just wanted to say i know it dont look good but it wasn't supposed to look good just work right. i think after i get her all done im going to drive it back to Florida then sell it.. i want an 89 extended cab 4 cylinder. so im just getting it back together to make it home and sell, its sad to put this much work into something im not keeping but i just dont like the v6s.
ANYONE SEE ANYTHING IVE DONE WRONG SO FAR?
Old Nov 9, 2008 | 04:15 PM
  #103
76ANTHONY's Avatar
tstat housing is correct in the last pic, thats one question u had i think. next question is the crank key, well i would replace the key but if your gonna sell it then it will last for a year or so. what was the others???
oh and by the way, woohooooo your gettin her done
Old Nov 9, 2008 | 04:41 PM
  #104
Jay351's Avatar
If you didn't like the 3vze, why didnt you just do the 3.4L swap... Better v6 with almost as good mileage as a 22re..
Old Nov 9, 2008 | 04:46 PM
  #105
YoterUp's Avatar
Yeap whoo... get er done.. i didnt want to do the 3.4 swap on this one didnt have the $ or a 3.4.. i had a new 3.0 that turned out to be junk practically from jasper!
And my question on that water pump pui isnt about the tstat that circled part falls out now its just sitting in there it doesnt seem right how do i fix all that?
Old Nov 9, 2008 | 08:14 PM
  #106
YoterUp's Avatar
Thumbs down All My Questions As Of Right Now!!!!!!!!!!!!!!!!
Do you use RTV anywhere on your intake?
Any tricks to making sure you put your heads on Perfect?
How do you oil your heads once you put them back on? should i just dump some regular oil in there and rub it around? or do you use some kind of grear lube in specific places?
Im having trouble with my oil pan i have at the same bolts that came out of it but half of them wont re thread? is it just me not doing something right or has anyone else had this happen? do the bolts go in a certain order or place?
Does anyone have pictures of setting timing the right way?
i haven't looked on here yet just asking all my questions at one time.
Om my water pump one of the brass pieces came out how do i fix that or can it be fixed? I have it circled 7 posts before this i already asked this question no one answered.
Anything to remember as i finish this up? anything that's tricky and i may overlook?
THANKS FOR YOUR HELP AHEAD OF TIME!!
Old Nov 10, 2008 | 05:08 PM
  #107
76ANTHONY's Avatar
1. no rtv on the head or intake install and i had no leaks.
2. heads on perfect?, follow the directions on the sticky above for the manual.
3.oil your heads? hmmmm, cam lube when installing cams.
4. this is my favorite question, oilpan bolts no worky, ok heres what i did, HOME DEPOTTTTT. got new bolts because the oilpan gasket was a little more thick on the new install, and the nuts, well i just finesed them in
5.look in the sticky for the manual, it shows an awesome diagram, now remember to turn the engine over twice to check your final timing. yes it will be off, yes you need to redo it. you get the hang of it, i think i advanced the 2 cam sprokets to get it dead on. oh no pics, sorry
6. the waterpump brass thing, hmmmmmm. never had that issue
hope this helps.
Old Nov 10, 2008 | 05:11 PM
  #108
76ANTHONY's Avatar
ok i looked at the pics again, on your tstat housing that tube, well lets just say JB WELD is your friend
Old Nov 11, 2008 | 06:35 AM
  #109
YoterUp's Avatar
THANK YOU!!
I didn't think anyone was listening to me! ill do an update today it porbley wont be much its damn cold!! i do get the keyway today tho! i need some FIRE!!! lol
Old Nov 11, 2008 | 10:30 AM
  #110
YoterUp's Avatar
Todays Update 11/11/08
GOT SOME MORE DONE, its looking like a motor today!
1st thing is i went to the dealership and got My key way.
Then got the intake and the valve covers put on
MY ANTI ANYTHING FALLING INTO THE INTAKE AGAIN METHOD LOTS OF PAPER TOWELS!!!
Looks like a motor again!!!
Still doesn't look nice but i hope on everything it runs right!!!
GET ER DONE!!! leave me some comments!!!!!!!!!!!
Old Nov 11, 2008 | 01:14 PM
  #111
YoterUp's Avatar
Cool Update 2 11/11/08
Ok so on last post i was going to be done for the day but then decided i had a little extra time and went to do a few more little things ended up staying out there a few hours you know how it works out!!
NEED HELP NEED HELP NEED HELP.........DOES ANYONE HAVE A PICTURE OF THE "A" BOLT THAT GOES INTO THE HEAD HERES PICS AND WHERE THE BOLT GOES ON EACH SIDE...THE BOOK CALLS IT THE A BOLT!!!!!!HELP HELP HELP!!
Got a prety good amount done today i should have done a few more in detail pictures but i was a little more worried about getting stuff done then taking pictures!
Old Nov 11, 2008 | 08:06 PM
  #112
YoterUp's Avatar
Thanks again for no help guys!!
Cmon 76ANTHONY bail me out again!
Old Nov 11, 2008 | 08:13 PM
  #113
toyospearo's Avatar
That thing is lookin sharp!!
Old Nov 11, 2008 | 09:44 PM
  #114
76ANTHONY's Avatar
a-bolt??? wth never heard a that, lets see what i got for ya, hmmm, dam i got no pics of it. its just a short head bolt if i remember right, let me go look in the garage at my head bolts i had on there................
dammit, ya got me stumped on that one
wait
wait
wait, i yhink i got a pic
save it to your pics and blow it up, its a standard bolt thats black, oh and this one of my favorite pics, ummmmm maybe i need a taller garage door?
Old Nov 11, 2008 | 09:45 PM
  #115
76ANTHONY's Avatar
oh and you owe me a beer
and that things lookin good, she'll be running in no time......
Old Nov 11, 2008 | 09:59 PM
  #116
YoterUp's Avatar
Talking
I see it... well i tried to see it but i cant blow it up without distorting it i just went back through my old pics from the beginning and i think i found it it looks like a regular bolt it doesn't have the top like the head bolts do hum?
Im also wondering why your motor is coming out sideways what that a special thing that Toyota did with 4 runners i didn't know they put sideways front wheel drive motors in them? gotta give you a hard time about doing everything (sideways) backwards
and the garage looks to be just a little short, do you have a rebuild thread on here? or have you not done it yet?
I want to get it all put together tomorrow and get it on the cherry picker and ready to drop in on Thursday that's the plan so then i can do plug and play Friday and bleed the breaks and clutch then test drive Saturday and first oil change Sunday and then ill be ready for my 1200 mile test drive on Monday back to Florida before it snows any more here!!!
Hope for the best Prepare for braking down in the middle of no ware!! GO YOTA
Old Nov 11, 2008 | 10:12 PM
  #117
76ANTHONY's Avatar
nope no real build thread, and i was jerry riggin that biatch ta come out, lmao it was fun taking the front wheels of and shiat ta get her out, dohhhhh. and mtgoat had just warned me about height checks, lol. guess im not a good listener
and dammit ya got me lookin for 4runners, im not im not im not
oh and yes its just a standard bolt head on that one
Old Nov 12, 2008 | 12:12 PM
  #118
YoterUp's Avatar
TIMEING SUCKS!!! i lost my tensioner spring and mount so now i have to order that. im going to go look through all my crap 1 more time and HOPE i find it, Never buying a 3.0 again
Old Nov 12, 2008 | 12:20 PM
  #119
76ANTHONY's Avatar
ok, one more word of wisdom....if your loosing shiat, your going to fast. slow down and do it right, there is really no room for error on a 3.slow, trusttttttttt me.
take your time and try to enjoy the building process....
and how the hell do you lose a spring and bracket?????? get ta findin that shiat buster
Old Nov 12, 2008 | 03:42 PM
  #120
76ANTHONY's Avatar
find them parts yet?
