3VZ Rebuild
Old Oct 24, 2010 | 01:22 PM
  #361
808-3VZE's Avatar
Originally Posted by camo31"10.50"
ah i see, glad to hear it's running good dude!!!!!!!!!!!!
honestly, only time will tell, i REALLY want to go with a Diesel swap...with either a VW 1.9L TDI diesel,or a Mercedes OM617 5cyl diesel...used to have a jetta with a 1.9L TDI and it ended up being a nightmare but had about 260,000 miles on it....
and i've heard the 5Cyl mercedes motors are bulletproof, and have lots less wiring since they are older.
i look at it like this:
Diesel fuel cost more, but a Diesel motor in my 4runner could/would get better than 25mpgs.
Gasoline costs less, but a 5vz will only get (AT BEST) 20mpgs......
so it would cost more per fill up at the pump with the diesel, but in the end costs less overtime.
and who doesn't want to see an old 4runner rollin' coal with the big rigs
That would be a mean swap! I think diesel is the way to go bro!!!
  #362
808-3VZE's Avatar
another reason for me to swap my 3vz for a diesel, is that i have a full Bio-Diesel processor in my shop...so i could be making my own fuel for around $0.55 per gallon...and still be getting over 20mpg's
Damn! Wish i could make gasoline at my job!!!
Old Oct 24, 2010 | 09:32 PM
  #363
camo31_10.50's Avatar
lol making gasoline is pretty damn hard.
making Bio-Diesel is a piece of cake
Old Nov 1, 2010 | 06:40 PM
  #364
southerncomfort4x4's Avatar
What To Do? Help!
Ok so this is my first post here and so far have found alot of very useful info on here, my question is I have a 91 4runner I just got for very cheap with a blown HG, turns out that was all that was wrong. I have it torn down to the block still in the truck and the odometer says 237,000 but the cylinder walls dont even have a hint of ridge at the top. Should I go ahead and rebuild the bottom end or just rebuild the top end? Was hoping to not sink a lot of money in it and just get to put some miles on it before a engine swap down the road, but not sure now.
Old Nov 2, 2010 | 12:56 AM
  #365
TNRabbit's Avatar
Did you do a compression test before you broke it down?
If the HG was blown for long, you might have bearing issues (first thing coolant in the oil destroys). Might need to pull the oil pan & have a look-see at one of them....
Old Nov 2, 2010 | 01:30 AM
  #366
ChefYota4x4's Avatar
Start a thread, SoCo, ..... You'll get plenty of input if you do... probably wont get much on the thread of someone else, ya know? I'll be looking for your thread. Best wishes. (PS> might help in it to put TONS of details, especially which motor, etc.)
Old Nov 2, 2010 | 04:33 AM
  #367
Ok I'll start a thread soon, took tons of pics as I tore it apart and labeled everything. It is the 3.0 3VZE. Engine just dosen't seem to have that many miles on it but I don't know of any way to be sure other than rebuild. The cylinders are slick as glass and no ridge what so ever, but #1 was pumping the h*ll out of some water.
Old Nov 2, 2010 | 11:57 AM
  #368
Yeah, TN is right... and the bearings wont be that far in to check out once you get the pan off, ya know? If you have POLISHED holes... not good for compression, ya know? Sounds like it really worked in the water for a while before the HG finally blew, actually, SoCo.... Maybe?
Best wishes, sling a post here as to when you start the thread, K? LOTS of 3.0 guys on this site. I'm not one of them, lol...but I might be of some help, K?
Mark
Old Nov 2, 2010 | 12:35 PM
  #369
TNRabbit's Avatar
I pumped a ˟˟˟˟˟load of coolant through mine & it did a number on the bearings. So, what turned out to be a HG replacement turned into an entire engine rebuild. It's around here somewhere, but putfile went tits up & lost all 1900 photos I had linked in the thread...>DOH~!
I showed ZERO wear on my cylinder walls at 218k miles. Mic'd them & checked every which way; cams were fantastic, just the bearings were ate up a little bit.
Old Nov 2, 2010 | 06:55 PM
  #370
Ok thx for the help guys. Guess i'll be spending more than I wanted to right now. I'll start a thread when i get dug in.
Old Nov 6, 2010 | 04:26 PM
  #371
how would i go about Flushing my cooling system?
i seen some fuggin orange RTV in the top of the radiator of my 3vz.......keep in mind i used NO ORANGE RTV on this job...so it's been stuck in the radiator...
need to flush it out nice and good...any ideas?
Old Nov 9, 2010 | 12:32 PM
  #372
they're cheap to work on dude? LOL
i've spent about 1200-1400 on my rebuild? complete rebuild..
if you go to the Dealership than it's going to be expensive for a rebuild of ANY motor..not just Toyota.
you want a wiring harness...why? go to a junkyard...boom! less than $100!
Old Nov 9, 2010 | 05:00 PM
  #373
murphyz's Avatar
Originally Posted by bassfrad
Toyota's suck. I have rebuilt 3 and they are stupid expensive to work on. Toyota wants $1350 for a computer and $2000 for a wire harness. $3000 to rebuild a 3.0 V6 if done correct. That is out ragious. Stay with american made or move to Japan. IMPORTS SUCK
you sir are an idiot
Old Nov 18, 2010 | 03:05 AM
  #374
Terrys87's Avatar
Southern comfort.. these motors usually dont get ridge rings like domestic motors, even with lots of miles, I would probably just go with a topend rebuild if I knew the previous condition of it, if not I might would go a little further, depending on funds, just mt 2 cents
Camo.. I would pull your radiator out and take it to a rad shop and have it power flushed. Those Preston kits help but they cant clean your radiator out. It cost me $25 to have mine flushed and each one had looked good until I had it done it and it makes a difference. These are going on 20 + years and have a lot of build up.
Old Nov 18, 2010 | 12:07 PM
  #375
hmm...thanks Terry i believe i will do that!!!!!!!
yesterday i was letting my truck idle for a bit...and i've let it idle for longer before..and the temp gauge never moved past the middle.
well yesterday i looked down at the gauge.....and it was ALMOST touching the red.!?!?!?!?!? scared me...so i took off like a bat outta hell driving down the highway...(t was about 40* outside) and it cooled back down to the middle of the gauge within about a minute or two...and it was fine the rest of the night..didn't overheat again.
i also noticed that if i drive down the highway before the truck is fully warm....it won't get warm until i get into town and drive slower....this sound right to you guys?
it's been between 55*-32* when these things are happening.
Old Jan 7, 2011 | 05:38 AM
  #376
pwd's Avatar
pwd
Have you solved the overheating issue? Unfortunately I don't have and really useful info; my only though is that there may still be air in the cooling system or a pressure leak from a bad cap.
Old Jan 8, 2011 | 09:29 AM
  #377
i believe it's a bad radiator cap...i've gotten all the air outta the system like 3 times..and it's still got that "rushing water" sound when i start it up.
my rear heater doesn't work either...no matter what i do...anybody got any advice on that?
Old Jan 10, 2011 | 09:37 AM
  #378
northeaster79's Avatar
I'm not totally familiar with the 3.0,I am about to be.Just got another 1st generation runner that needs head gaskets.I did however do a head gasket job on one several years ago,and found that it was very hard to get all the air out of the system.The rushing water sounds to me like you have air in there somewhere which could give you your overheating problem along with your no rear heat.
How are you purging the air from your system?
Old Jan 11, 2011 | 11:48 AM
  #379
i put the front up on some small ramps (bout a 1ft tall) so the radiator is the highest point, take the cap off, make sure the fluid is full, start the truck with both heaters on full blast.
and wait till it the air bubbles stop poppin out, ran it like that for 15-20mins...on more than one occasion.
Old Jan 12, 2011 | 04:44 AM
  #380
Try leaving your rad cap on loose(first click) and drive it around town a bit,that should get all your air out.
