Old Feb 10, 2016, 09:25 AM
How-Tos on this Topic
Last edit by: IB Advertising
    Print Wikipost
    2nd gen 4runners lift guide
    Old Nov 1, 2009 | 10:07 AM
      #201
    MaK92-4RnR's Avatar
    Decided im going with a TOYTEC lift, buying all the parts listed... extended shocks, coils, and the spacers. then i'm also doing a 2 inch body lift... anyone have any objections to this?
    Old Nov 9, 2009 | 07:53 PM
      #202
    HiluxAlberta's Avatar
    I have bought all the FJ80/BJ + Brackets set up; But I keep reading on other forums that its worthy to purchase a LC spring adaptor plate that sits on the top, or else you can have the spring pop out.
    How true is this?
    Old Nov 10, 2009 | 05:06 AM
      #203
    Lumpy's Avatar
    Mine seated quite nice, I don't think they are going anywhere. There is not enough room for them to go anywhere.
    Old Nov 10, 2009 | 05:06 PM
      #204
    That Guy's Avatar
    clarify
    i have a few diffrent questions with the fj80 rear coil setup on the second gen 4runner. to clarify a few things.
    1. can you use one set of the fj80 coils or do you have to have two off the same side?
    2. do you need the panhard bracket? and where can you purchase it?
    3. do you need extended brake lines? and where to purchase this?
    4. and do the OME 901 hD (i believe that the name) serve the same function (lift wise) as the fj80 coils? and are the same mods necessary to implement them?
    just wanted to clear this up because the thread is a little confusing. i know this has been beat to death but i appreicate your responses
    thanks
    Old Nov 10, 2009 | 05:32 PM
      #205
    DC Hoerunner's Avatar
    That Guy
    1= you can use one set just make sure that if one spring is taller than the other put the taller spring under the side with the gas tank.
    2= you do need to add a panhard bracket which is sold by 4 crawler. http://www.4crawler.com/4x4/ForSale/...ngSpacer.shtml
    3= you would feel much better if you did put in longer brake lines or else you will severely over stretch your stock ones sorry but you'll need to search for where to get those try marlin
    4= and yes they are virtually the same the 901 hd's will be a stiffer ride though which could possibly decrease rear articulation.
    Old Nov 10, 2009 | 05:35 PM
      #206
    That Guy's Avatar
    thanks man, thats exactly the answer i was hoping for, i really appreicate it
    Old Nov 22, 2009 | 02:16 PM
      #207
    94Beast4Runner's Avatar
    So a friend and i split on two sets of fj80 springs. I know have the chioce of either the shorts or the longs. i'm putting in 1.5" bj spacers in the front. I would like the truck as level as possible. Which should i choose?
    Old Nov 24, 2009 | 02:06 PM
      #208
    you can use either set. the taller set won't give an extremely noticeable change over the shorter set.
    when combined with only the front spacers the rear will still be higher but you have to really look for it so you will be good with which ever set you choose
    Old Nov 28, 2009 | 10:43 PM
      #209
    snowshredder555's Avatar
    this is how she sits now...
    Running 35's..901 OME's rear, 1.5" RB BJ Spacers front, really cranked the t-bars..Super stiff front end...
    Purchased Sway Away T-bars for the front...need time to install...should soften the ride a little..
    Old Nov 29, 2009 | 05:33 PM
      #210
    91_TOYOTA_4x4's Avatar
    that looks nice! ^^^ i like how there is no body lift .
    all sounds good to me but i wouldnt do a body lift imo they look wonky and i cant stand the frame hanging down so far. the most i would go would be 1" to just barely fir a 3.4 . imo its all susp lift
    Old Nov 29, 2009 | 06:09 PM
      #211
    MaK92-4RnR's Avatar
    yee be needin' a 2" body lift to be fitting yee 3.4... a 1" just wont do... heh
    Old Nov 29, 2009 | 06:36 PM
      #212
    o i will make it do lol smash the hood up a bit, cut it, i dont care but i wont go over an inch of BL haha. do i hear hood scoop?
    Old Nov 30, 2009 | 01:34 PM
      #213
    MaK92-4RnR's Avatar
    /cough 2" body lift... heh
    Old Nov 30, 2009 | 02:07 PM
      #214
    camo31_10.50's Avatar
    yep..2" body lift is a must...and it makes things easier to work on LOL..
    Old Nov 30, 2009 | 02:38 PM
      #215
    /cough cough nop. hood scoop is a must then no body lift for me. didnt 904runner do it withpout a body lift? didnt he just smash his hood up a bit to fit it?
    Old Dec 1, 2009 | 09:59 PM
      #216
    Boomin4Runner's Avatar
    out of those lifts which one would you recommend for someone who is hauling around a lot of gear in the trunk i either just want to keep it stock and level it out or go big
    Old Dec 2, 2009 | 10:07 PM
      #217
    twitch6989's Avatar
    i went with the cruiser coils and ball joint spacers. 09' tundra shocks in the rear and toytec extd. lenght shock in the front. and mine sits lower in the front how can i fix this with out messing with the t-bars.Name:  0813090734.jpg
    Old Dec 2, 2009 | 10:13 PM
      #218
    MaK92-4RnR's Avatar
    ball joint spacers...
    Old Dec 3, 2009 | 07:31 PM
      #219
    turn them T bars lol if you already have bj spacers then i dont know what else you could do but crank em a bit?
    Old Dec 4, 2009 | 09:39 AM
      #220
    MaK92-4RnR's Avatar
    Originally Posted by SR5
    First off let me explain that you do not need a lift kit to fit 33x10.50 or 33x12.50. the 10.50 will fit with no rub at all, while the 12.50 will fit with some rub, backspacing will help take care of that rub
    example:
    Also you can do a body lift for Farly cheep
    Example with 2" body lift
    Ok So im gonna be getting some Cooper Discoverer STTs How badly will a 33x12.50 rub if i leave it stock height for a day or two? would I be able to get it mounted and drive it home and then next day get a body lift done?
