22re first crank no start second crank fires rite off
as it says, 1986 22re, if you go out and try to start it, the first time you crank on it, it wont do anything, but second time you crank it it fires off. it can be a super fast like two revolution first crank and itll still start on the second try. cold start injector tested good, cold start temp switch tested good, any ideas would be great!!!!
i let it sit for a few hours and went out and cracked the cold start fuel line and it still had good pressure in it, so i assume its not bleeding off, and it starts fine after its warmed up ( i know that basicly leads back to cold start system)
okay, there are 3 things you need to run a motor (basically), fuel, air, and spark. pull your plugs and set them next to one of the nuts on the valve cover to see if you have spark, thatll be easy. are you sure youre gettin fuel? and then its air, vaccuum test and see if the afm is clean, maybe look at your air filter, but seeing how it will run i dont think its air.
This is a common thing, I believe its the fuel pump just being slow because of how it is wired. Nothing is wrong with the fuel pump, it just doesn't turn on right away, thats why it always starts quick on the second crank but does nothing on the first. I think 4Crawler did a write up on his site on how to fix it.
does an '86 have an FP (and B+) in the diagnostic connector? As Alberta4x suggests, you may have a weak check valve in the fuel pump, which allows the pressure in the line to drop with the pump off (your CSI test suggests otherwise, but you'd still get fuel spray from "too low" pressure).
If you have the FP connector, jumper it to B+ (or just the battery), turn the key on, count to three, then start it. If it starts right up you've found your problem (waiting with key-on and no jumper doesn't help, as the fuel pump doesn't turn on until you turn the key to "START").
Check the vacuum lines to the fuel pressure regulator.
You have it plumbed to the wrong spot.
Best way to check the vacuum line plumbing is to use the diagram on the underside of the hood.
You can blow through the vacuum lines to verify where they go.
It sounds hoaky but it works.
All lines are connected to the rite spots per the diagram on the hood checked it last night. I noticed when it first starts the tach acts funny for a quick second. Gona swap out coil and ignighter tonight see if that helps. Thanks for all the ideas so far!
Idle should drop to normal pretty soon after starting unless it is below freezing, not sure how far below freezing it has to be though. Its so cold up here that my truck always idles up for quite a bit when it starts haha
well changed the coil and ignighter, and changed the air box lid out with a different one, gona try it again tomorrow night, it dont have the test/check port so i cant hotwire the fuel pump. its just so odd that it wont start on the first try but kicks off good on the second try. getting irratated lol
MMA_Alex
25
Apr 18, 2017 05:07 AM
