22RE aftermarket temp gauge
Old Jan 25, 2011 | 12:38 PM
Beefmaster's Avatar
I'd like to install an aftermarket temperature gauge as a backup to my intermittently-working in-dash gauge (SR5 cluster). My question is, where is the best place on the engine to install the aftermarket sender without eliminating the factory sender? My existing problem is a faulty gauge (and not the factory sender) because a good, hard slap on the underside of the instrument panel will wake the gauge up for a little while.
87 4Runner SR5
22RE
5 spd.
Old Jan 25, 2011 | 12:43 PM
blake.nemitz's Avatar
well you could tee it off the factory location
Old Jan 25, 2011 | 12:49 PM
Beefmaster's Avatar
I thought of that, but was concerned that unless the tee could vent (which wouldn't be a good idea), the sender might be suspended in hot air, and not hot water as it is meant to be, and that may give an incorrect reading. But I could be wrong...
Old Jan 25, 2011 | 12:51 PM
you could make a piece. cut top radiator hose in half and fashion a copper union in there with a port for the sender, some guys run like this for an electric fan thermostat no pretty but it works
Old Jan 25, 2011 | 12:54 PM
T_F_E's Avatar
No you cant tee off for a water temp gauge because it wil not flow over the sender
Old Jan 25, 2011 | 12:57 PM
BigBluePile's Avatar
You can put it in the upper rad hose:
Old Jan 25, 2011 | 01:02 PM
Beefmaster's Avatar
BigBluePile,
Did you build that coupler in your upper radiator hose? What's it made from?
Old Jan 25, 2011 | 01:21 PM
spc mike's Avatar
You should search. I found this in about 40 seconds:
http://cgi.ebay.com/ebaymotors/Water...Q5fAccessories
Old Jan 25, 2011 | 01:36 PM
Beefmaster's Avatar
That would do it. Thanks.
Old Jan 25, 2011 | 01:38 PM
xxxtreme22r's Avatar
on the drivers side of the block I believe there is also a coolant drain, but not sure on what effective side of the t-stat it is.
Old Jan 25, 2011 | 01:45 PM
Originally Posted by Beefmaster
BigBluePile,
I ordered mine thru LCEngineering but you can make your own...or ebay!!
Old Jan 25, 2011 | 01:51 PM
4Crawler's Avatar
You could pick up a t-stat housing from an automatic or turbo truck, it'll have additional threaded holes for senders in it.
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Nickyodaman
Jul 27, 2015 12:13 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Poncho0206
Jul 10, 2015 06:21 PM
