190 hp 3.0 V-6 from CHS Machine 210 Torq
Old Jun 25, 2011 | 08:21 AM
Wildblue's Avatar
The above chart was the dyno report from their original build. The power is from the hot cam and the reworked heads. Purchased their proline rebuilt $1995 with seven year 70,000 mile warranty. They are promising a lot of new ponies with this build. Will post later about how the install goes and then report on how this new dog barks.
Wildblue
Old Jun 25, 2011 | 08:41 AM
MudHippy's Avatar
Right on! I've been wanting for somebody to pick one of those up and test it out. Very curious if it's worth it. My gut tells me it's a good deal. And I'm assume you'll be happy with it. An engine is just one of those things I don't want any part of unless it came straight from the OEM factory or I built it myself. Too many idiots "think" they know what they're doing.
Anyhow, I hope all goes well. Honestly. It's entirely possible I might consider buying one too. IF I don't run into any reports of dissatisfaction in the mean time.
Old Jun 25, 2011 | 09:38 AM
Wildblue's Avatar
Smile
So far at least CHS has been great to deal with... Engine ready for pick up on Tuesday of next week. Says they do about 200 units / year and have never had a problem. The Ebay seller rating is high and they have had 11 complaints filedith BBB over 15 years and most of these are resolved. No indications of any problems... will go over the warranty thoroughly with them so we are both clear on how the install and break in is going to go down. Now hopefully that fifth gear will have more value
Old Jul 2, 2011 | 05:29 PM
Wildblue's Avatar
CHS quickly approved the engine core for rebuild and refunded the $500 core deposit on my credit card. Had to drive (three hours return) twice into Portland to pick up pieces missed on the old block (long block was recieved without a side water port cap) and they missed a cam dowel and most of the studs and oil pan bolts. My mistake was don't give up your core until you are sure you have all the bits). I wanted to compare old and new block side by side but my old block went in the back shop door and the new long block came out the front door and the shop mamager chased me out for safety insurance reasons. Small stuff....been fighting down some engine codes but basically the 92 4x4 Yoda runs like a bat out of hell. So far at least would recommend this shop with out any hesitation. This bitch rocks and i'm groovin on it!
Old Jul 2, 2011 | 05:45 PM
Birdbrain's Avatar
Very cool!
But hey mate, watch the language!
Old Jul 2, 2011 | 05:48 PM
MudHippy's Avatar
Nice!
Sounds like you're about twice as far as I am from P-town. Takes me 45 min. one-way(haulin' balls-out).
Take me for a spin....better yet, I'll race ya in my 98 Monte Carlo!
3.1L SFI V6 160 HP 185 FT-LB Curb Weight ~3300 lbs.(pulls hard all the way to the governor @ 105 mph, thank you NASCAR pedigree for the aerodynamics involved in that!)
Whatta ya say to that?
Old Jul 2, 2011 | 05:49 PM
Birdbrain's Avatar
So its $1,995 before or after the core?
Can you tell us the process more? If this thing is as awesome as it sounds i might just do that than a 3.4 swap!
Old Jul 2, 2011 | 05:52 PM
ToyoTech559's Avatar
sounds good, wheres them pictures at
Old Jul 2, 2011 | 07:33 PM
Wildblue's Avatar
Truck was originally from Boise Idiho (desert dry with absolutely no rust on frame and body) ... will have to cut the sun fade off the paint with a compound and will post pics at some point. l do not know what the 3.4 swap experience is, but I am very happy with this 190 hp head cam option. Been doing some runs up the columbia valley clearing codes and the negbors are remarking about that K&N air filter exhuast pipe growel. This has put some serious Yo in the 3.0 slow Yoda!
Old Jul 2, 2011 | 08:05 PM
Wildblue's Avatar
The 190 Hp engine costs $1995.00 after they confirm your core is rebuidable...They charge you the $500 core charge unitll they inspect your core... in my case they just looked at the bottom end (was not smoking) and they said i was good to go.
Old Jul 2, 2011 | 08:13 PM
Wildblue's Avatar
Was at family in Willamina Or.... now back in Cilliwak BC... would love to let you play with the yoda rig, but unless you are up this, way won't work.
Old Jul 2, 2011 | 08:38 PM
bone collector's Avatar
subscribed. is complete engine only?? or can u buy heads/cams etc from there??
Old Jul 2, 2011 | 09:18 PM
MudHippy's Avatar
Originally Posted by MudHippy
...I've also been meaning to get ahold of a company near me in Portland, OR,(CHS Machine Co.)that sells a "Hi-Pro" 3VZE with high lift/duration cams in it.
Still haven't called to ask about the cams...should. That was from the WEASY'S/COLT cams thread.
Here's what we're talking about.
TOYOTA 3VZE 3.0L V6 REMANUFACTURED HI-PRO / HEAVY DUTY ENGINE
190HP @ 4800 RPM / 210FTLBS @ 4800 RPM
THIS ENGINE HAS THE FOLLOWING:
NEW HYPEREUTECTIC PISTONS.
NEW ALUMINUM PERFORMANCE ROD & MAIN BEARINGS.
NEW THRUST BEARINGS.
NEW OIL PUMP.
NEW FULL GASKET SET.
NEW MOLY PISTON RINGS
NEW BRASS FREEZE PLUGS
NEW TIMING BELT
NEW OVERSIZED VALVES, GUIDES & STEM SEALS.
HIGH PERFORMANCE CAMSHAFTS 222 DURATION-.400 LIFT.
MACHINE WORK
Bore and hone block with torque Plate with moly finish.
Deck cylinder block parallel to main line with CBN.
Re-size connecting rods.
Hang and align new pistons onto connecting rods.
Line hone main line.
Grind & polish crankshaft.
Grind & polish camshafts.
Remanufacture Cylinder Heads.
Adjust valves.
Assemble.
Fully balanced assembly!!!
ALL OF OUR ENGINES COME WITH A
7 YEAR / 70,000 MILE WARRANTY!!
ENGINES ARE SOLD EXCHANGE
CORES MUST BE REBUILDABLE
Price: US $1,995.00
They've got a HIGH PERFORMANCE 135 HP/173 FTLBS 22RE too.
http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories
Old Jul 2, 2011 | 09:49 PM
eric924run's Avatar
I glad to find someone that went with that motor. I was to scared to be the gineapig. Great to hear it running strong. please keep us informed how it works out after you put some miles on it.
Old Jul 2, 2011 | 09:57 PM
phildelfino's Avatar
seems like a good deal. need more test data, like in 10,000 miles how's it doing.
intriguing.
Old Jul 2, 2011 | 11:48 PM
more info on the process of say i want to do this as well if u can. also long term updates would be nice. im sure my 3.0 will go out soon and it seems like a less of a headache to just rebuild or do what you did instead of going 3.4swap
Old Jul 3, 2011 | 02:52 AM
dropzone's Avatar
Fossilized
personally I would love to see some pics of this thing.
that being said, it is nice to have found another local/reliable source in case I need a long block for my '81. price is not too bad with a $300 core
Old Jul 3, 2011 | 02:31 PM
Wildblue's Avatar
Pic file size limits ??
Tried to upload a bunch of pics but the site does not permit anything over 48 kbytes files size. Thats thumbnail size. Whats up with that?
Old Jul 3, 2011 | 03:21 PM
skypilot's Avatar
Do a flickr.com or a photobucket.com then post the link.
Old Jul 3, 2011 | 04:07 PM
Wildblue's Avatar
OK
Will do...
Thx
