Reviving a tired 85 4runner
#41
Somewhere here recently someone posted the hose sizes and a general amount you need to buy. The silicone hoses in lengths you cut weren't too expensive on eBay. The kits seem to be a rip.
Here's the installation instructions from softopper. If you need any parts they are good to deal with:
http://www.softopper.com/installation.aspx
#42
#43
hey guys, 2 quick questions, one how hard is it to swap a 3rz into a 1st gen 4runner? i found a motor and tranny with ecu for 350$. also, how hard is it to convert a 22rec to a 22re, from my understanding the 22rec is just a california spec model with a bunch of emissions bullcrap.
#44
http://toyonlyswaps.com/
http://board.marlincrawler.com/index.php?topic=19275.0
3rz swap sounds good. 150 HP stock and you can supercharge or turbo and go big.
05+ has 164 HP.
05+ has 164 HP.
#46
donomite, thanks for the toyonlyswaps link, i cant open the other one for some reason though. and b-fake, the main problem is i dont have a garage, second problem is this is my daily
id have to do the swap at school. and im pretty sure i cant swap it in 8 hours. i guess its a dream or wishful thinking. but ill post the link for anyone in the NC area if theyre interested. guy says 101k miles. as far as converting a rec to a 22re, has anyone done this?
#48
Making the 22REC an RE is pretty much just removing the unnecessary emissions crap. I don't know the details involved, but I'm sure a quick search can lead you in the right direction. Someone on here has to have done it before.
#50
A couple of posts back you asked about vacuum hoses. LCE has a kit for $29.95. According to them for a 22RE you need:
12 feet 4mm
6 feet 6 mm
1 foot 8 mm
Check eBay. I think it's about $1 a foot there.
12 feet 4mm
6 feet 6 mm
1 foot 8 mm
#51
thanks nervo. this is a 22rec, so i got all those extra bs vacuum lines to deal with. thinking of looking more into an emissions delete. wish i could find a successful thread on a swapped over 22rec to 22re.
#53
Here's a link to the FSM, should tell you the differences between the two in the emissions control system section.
http://www.functionalfab.com/resourc...%204runner.pdf
Might take a bit to load, it's the whole manual, but you should be able to save it to your computer from there.
#54
basicaly the 22re is a federal 49 states engine and the 22rec is the california 50 state engine. it has more emission bs on it.
UPDATE!; FINALLY GOT THE FREAKING NEW MANIFOLD ON!!!! im so happy. lol. doesnt tick more than any normal 22re now
went with a dorman exhaust manifold. for 60$, its decent quality. bolted right on. pretty close to a factory manifold. learned how to used helicoils tonight aswell. btw i got a whole box of 10x1.50 helicoils if anyone wants to buy em half price. i only needed one. kinda sucked having to pay 40$ for it.
#55
hope you find the power you're looking for. Also you might look into swapping the battery and intake locations. i haven't tried it but i have read a few threads where they have and it helps some. it doesn't seem to hard either. i would post a link but i can't find the thread now, if i find it or try it i'll let you know.
#56
#57
after thought...lce has a throttle body spacer for $80, that with the right intake, exhaust and most likely injectors (to keep a good ratio) would be helpful. almost all the stuff that people have said in this thread will get you a little bit of power or response. remember throttle body spacer!
#58
i got a snorkel so unless its like a 20 hp gain, i cant really bring myself to put another hole in it lol. and the tune up and maintenance has honestly improved the power alot. the valve adjustment seemed to improve my torque band and after i change the oil, honestly i think the rest could be the gearing, but i am no longer going into 3rd to climb hills. so hooray for that lol. anyone know anyone who has 4.88 aussies that want 4.10 aussies? shot in the dark lol.
#59
#60
okay. its been cold lately, and starting has been difficult, which is weird in a fuel injected vehicle. like it literally takes me 2-3 mins of cranking to start it. it not a slow crank though. just slow to actually start. so i dont think its the starter. its driving me nuts. it only happens when its cold though. it seems to me like its having trouble getting fuel??? but i dont know. it runs fine when it actually starts up. any ideas?
