Newbie with 1985 22r piston rings question...
Old Sep 27, 2009 | 08:55 PM
zach5150's Avatar
Question Newbie with 1985 22r piston rings question...
Hello. Have been watching the site for awhile now, and just decided to join cause i had a question about a truck I may be purchasing...
Its a 1985 4x4 standard cab 5 speed 22r....solid axles, brand new 33's, new weber carb distributor and a couple other things...BUT..when guy put on the carb it was set wrong, dumped fuel in motor and he says it friend piston rings. The truck is rust free on the body, and one minor spot on frame. It is a nice looking truck and is exactly what i want.
The question is...the guy wants 1200. I think its a little step cause it does not run....he said when he parked it it had serious blowby issue and oil was blowing out of the crankcase breather. So does that mean rings are fried? Would it be worth buying, selling weber carb, buying good used carb and rebuilding motor? What all will i need to do new rings besides honing brush and rings? Any help for the new guy would be appreciated...i really want this truck!
Old Sep 27, 2009 | 09:04 PM
seanmearse's Avatar
Offer 1K. Tell him its a rounder number that sounds better. He will take it. I have an 84, I love it to death. I paid 1500 for it, and granted it did have issues, but they are all mostly fixed. But, I will tell you this. These trucks, and the money you can spend on them, is very addicting. But yeah, if the truck is cherry other than the motor, snatch it up. And welcome to YT!
Old Sep 27, 2009 | 09:08 PM
zach5150's Avatar
i offered him 1k and even to trailer it from his house lol...so hopefully he budges. do u know anything about all the motor questions? lol
Old Sep 27, 2009 | 09:18 PM
seanmearse's Avatar
Compression test first, then try and start her up, he might have forgot something. Check it thoroughly, might even be something small. Check the plugs as you pull them too, you can read a plug. Google "how to check spark plugs", it should pull up what signs to look for.
Old Sep 27, 2009 | 09:26 PM
zach5150's Avatar
thanks...any other inputs will be appreciated..i will check forum daily and will keep u updated on the status of the truck!
Old Sep 27, 2009 | 09:35 PM
olharleyman's Avatar
Make sure you pull them one at a time so you don't mix up the wires and have firing order issue's that said if the rings are indeed shot You have your first project and there's lots of info and people here that can help you redo the rings.
Quick guide to reading spark plugs
1.If there is no issue the plugs should have a light brown almost hot coco like look to them
2. If they are black and sooty they are running rich to much fuel
3. If they are gray or white then they are running lean lack of fuel needed to run proper
If this don't make since I am sure you can GOOGLE it and see pictures to help you get a better idea of what I am trying to describe to you.
Old Sep 27, 2009 | 09:39 PM
zach5150's Avatar
yes i understand. Im pretty much planning on putting the new rings in cause the guy told me that they are trashed...other than honing brush rings and maybe a gasket or two..is there anything else i would need to do this
Old Sep 27, 2009 | 10:40 PM
zach5150's Avatar
and just for ur info..... http://louisville.craigslist.org/cto/1378160146.html
Old Sep 27, 2009 | 10:55 PM
seanmearse's Avatar
Dude! that truck is saweeeet! For the price, get it. I think it will be worth it.
Old Oct 18, 2009 | 05:44 PM
rbmoomba's Avatar
I'd do it in a heartbeat....by the way go back with Hastings rings only....cheap rings can become your next headache....they may not be easy to find but will be definately worth it
Old Oct 20, 2009 | 02:12 PM
toyotajake's Avatar
Hey man, sounds like a cool truck. if its got blowby, and spitting oil, I wouldnt condemn the rings. Sounds like something was installed wrong. Or someone forgot the rings alltogether. Even if they were really worn, it would burn a ton of oil, not spit it everywhere. But yea, try a compression test that would be your ticket.
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
84'22r
Feb 13, 2019 05:35 AM
dumpster84
Apr 30, 2016 06:03 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
