Leaf Spring Options
Old Oct 27, 2008 | 09:18 PM
stagger_lee's Avatar
Leaf Spring Options
I was talking to a buddy today about his FJ40 and future suspension plans. His plans were to run FJ60, rear springs all around. 3-4"s of lift, ridiculous articulation for cheap on a spring over.
My question, is there any common junkyard leaf to run on a 1st Gen 4runner to give a me a extra 2-3"s and clear 33" tires without having to move mount points other than maybe the far front 2. Chevy? I kind of want to keep her all Toyota, I'm OCD.
Old Oct 27, 2008 | 09:21 PM
SpecialScottie's Avatar
As for the front end I believe rear up front would be your best option. This also moves your axle forward and helps clear larger tires.
Maybe someone else with more knowledge will chime in
Old Oct 27, 2008 | 09:31 PM
Stock rears are a little low, but up front they might be perfect, huh? BRILLIANT! Anybody else run a random set up (not off the shelf?)
Old Oct 27, 2008 | 09:47 PM
I hear they give around 2 to 3 inches of lift depending on the spring pack used.
For the rear I cant think of anything toyota. But I have heard of many using chevy 63s. They are also supposed to give 2-3 inches.
Old Oct 27, 2008 | 10:08 PM
What do the chevy 63s come off of? I need to measure the fj60 springs. This was all sparked tonite.
Old Oct 27, 2008 | 10:15 PM
Jay1's Avatar
The chevy 63 come off chevy early 90's 1/2ton 2wheel drives.
Old Oct 28, 2008 | 04:16 AM
phildelfino's Avatar
1988 to 1998 rear Chevy leafs. Some have 3 in the leaf packs and some have 4 in the leaf packs.
Old Oct 28, 2008 | 04:20 AM
try this thread or do a search for chevy leaf springs.
pirate has an excellent write up on this install.
https://www.yotatech.com/forums/f115...prings-140015/
Old Oct 28, 2008 | 04:26 AM
BLKNBLU's Avatar
http://www.pirate4x4.com/forum/showt...=chevy+springs
Old Oct 28, 2008 | 01:24 PM
I believe they even came on the 4wds
Old Oct 28, 2008 | 03:33 PM
Thanks guys. I'll be at the junkyard measuring toyota springs to see what else I can find.
Old Oct 28, 2008 | 08:28 PM
Post if you find anything good
Old Oct 29, 2008 | 12:19 PM
85toy's Avatar
dont bother looking for toyota springs to put under your truck except for rears up front, even though the newer toyotas have longer springs, there is a reason no one uses them.
Old Oct 29, 2008 | 12:26 PM
and that reason is...
Old Oct 30, 2008 | 01:52 PM
Old Oct 30, 2008 | 11:05 PM
XtraSlow_XtraCab's Avatar
Can't you just get springs that are slightly "longer" than whats on now so you have more "loop"?
punks_is_4x4
May 31, 2016 06:03 AM
Kreedy1
Sep 8, 2015 06:33 PM
Regency
Sep 6, 2015 05:47 PM
northwalker
Sep 3, 2015 12:21 PM
Ryall
Sep 2, 2015 06:48 AM
