Brake problems
Old Nov 12, 2009 | 11:37 PM
RAMROD84's Avatar
Brake problems
i have an 84 Toyota 4x4 ext cab. last week my master cylinder went out. i ended up replacing my it. after replacing it i tried bleeding the brakes with a power bleeder. i started on the right rear. for some reason i am not getting fluid to the rear wheel cylinders. i get fluid to the front and up to the LSPV but not to the rear wheels. i bled the front and the LSPV with the power bleeder and by pumping quite a bit till solid fluid came out and i still am not getting any fluid to the rear wheels. i can kinda stop after i bled the front and the LSPV but i have to hit the pedal to the floor before i actually stop. if anyone knows what could be wrong i would really appreciate the help
Old Nov 13, 2009 | 04:50 AM
Etype R's Avatar
Can you get someone to help you bleed the brakes, and operate the pedal while you crack the rear bleeders? I don't have any experience using the power bleeders my self, though I did buy one from Harbor freight last winter. Just haven't had to bleed brakes since picking it up. Could be that with the LSPV the power bleeder isn't strong enough to pull fluid through.
Did you bench bleed the new master before installing it? If you didn't bench bleed it right, it could be the cause of your problems.
Old Nov 14, 2009 | 10:02 AM
RAMROD84's Avatar
i have all ready tried having someone help me bleed the brakes by operating the pedal and it still didnt help. iv never had to change a master cylinder before so i did end up installing it without bench bleeding it. i'll have to do that and see what happens
Old Nov 14, 2009 | 10:29 AM
Kiroshu's Avatar
Um thats you prob already.... you "HAVE" to bench bleed a master cyl or it won't do nothing worth a damn. Take it off and bleed it. You have to.
Old Nov 14, 2009 | 01:55 PM
RAMROD84's Avatar
i know, im going to take it off and bench bleed it. could that be the reason why im not gettting fluid to the rear wheels though? im getting fluid to the front and the LSPV but im getting nothing at the rear wheels.
Old Nov 14, 2009 | 02:40 PM
Kiroshu's Avatar
yea it could.
Old Nov 14, 2009 | 09:00 PM
RAMROD84's Avatar
yea it could.
ok well i'll bench bleed it and see what happens
Old Nov 15, 2009 | 06:26 PM
desertcamper67's Avatar
Lesson learned I'll bet.
Old Nov 24, 2009 | 06:37 AM
Nix_Toy's Avatar
If by 'power bleeder,' he means a vacuum (like mighty vac), then bench bleeding is unnecessary.
Old Nov 24, 2009 | 11:46 PM
RAMROD84's Avatar
Even with the power bleeder i wasn't able to get fluid to the rear wheels. After i bleed the master cylinder i was able to get fluid to the rear and now i have brakes again but they're not like the used to be. i would have thought that my brakes would be better with the new master cylinder. i think i might still have air in the lines. Im just going to have someone help me do the pump, hold, and release method and see if that helps
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
