Am I Screwed?!!??!
Old Sep 7, 2008 | 09:30 AM
eighty5yota's Avatar
Am I Screwed?!!??!
so i just got the back end back on after doing my 18 inch bob.
its not pretty at the moment, i gotta get in the shop tomorrow and tweak it.
basically i put it on cause i was getting hassled by san jose's finest.
but my question is this:
since i cut and boxed the frame right after the stock shackles, am i screwed cause i wanna put either a marlin,tg,or allpro 5" springs on? they all say they need relocation of the front hangers and the back needs to go back a few inches.. is there anything i can do?
heres a reference pic
Old Sep 7, 2008 | 09:32 AM
pepsibluefloat's Avatar
make the front hanger further foward
Old Sep 7, 2008 | 09:33 AM
am i gonna loose my wheelbase? cause the pin will be forward?
Old Sep 7, 2008 | 09:34 AM
i was thinkin something along the lines of a double shackle set up ? any info on this?
Old Sep 7, 2008 | 10:35 AM
NorCrawler's Avatar
yea a double shackle set up would move the back a little bit, you dont want to go too far forward on the front hanger because then you whole axle would be moved to far forward. with my double shackle setup its about 3 inches behind the rear hanger.
Old Sep 7, 2008 | 11:44 AM
grant526's Avatar
Nice Job on the Bob!
I saw a guy somewhere that had attached his shackles to the vertical on the end of your now boxed frame.
Check out the left Hanger. Something like this. But you will need a pretty long shackle! lol
Old Sep 7, 2008 | 12:27 PM
thats a great idea! thx for the compliment
i originally was going to cut up a hitch and put it in there or big d-rings so i made that plating out of 1/4 inch cold rolled steel.
if my truck got roadside bombed, those would still be there.
lets elaborate on this..
weld an aftermarket shackle hanger on the back?
with some nice pretty gold shackles..
bbboooiiiinnngggg
Old Sep 7, 2008 | 04:46 PM
grant526's Avatar
Ya. That sounds about right.
Old Sep 7, 2008 | 07:40 PM
4Crawler's Avatar
I ran 56" long springs on my '85 with the stock rear spring shackle location and a 7" c-c rear shackle:
- http://www.4crawler.com/4x4/4R_suspe...gerRearSprings
I now run a double shackle in back with similar springs. The upper half (3.5" c-c) is currently bolted to the frame and the lower half is 6" c-c:
TheBFA
Feb 15, 2020 06:55 AM
zytra
Jan 24, 2019 03:16 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
charlie_fong
Sep 27, 2015 10:06 PM
