Pre 84 Trucks 1st gen pickups
histeer power steering for a 1979
Old 06-22-2008, 10:01 AM
rottenagenda's Avatar
Hey everybody new to these trucks and need some help and advice
i want to to add powerstreering. and i figure lets just upgrade to hysteer has well. So what do i need, where do i get it and what works the best.
my truck is a 79 4x4 with a 20r
Old 06-22-2008, 10:32 AM
waskillywabbit's Avatar
High crossover steering requires at least 3" of lift.
So if you have that then you need a high steer kit, ps pump etc, idler bracket etc, IFS box and mount etc.
Let me know if you have any questions.
Old 06-22-2008, 11:00 AM
Kaleb's Avatar
Couldn't he just get a custom made draglink? One that is shorter to compensate for no lift?
Old 06-22-2008, 11:52 AM
is there any one that offers crosserover for a stock rig.
i realy want power steering and want to do it right
Old 06-22-2008, 12:49 PM
4Crawler's Avatar
With ni lift, you could swap in a stock '79-'85 push-pull steering box. You need about 3" of lift for crossover steering to make room for the drag link to pass between the frame and springs. I ran ~3" lift with my '85 and it was tight fit adjusting the drag link to not hit the passenger side spring under full droop and yet stay off the frame at full compression. You might be able to notch the frame for less lift and/or run a Jeep style drag link where is runs down to connect the the tie rod under the springs.
Old 06-27-2008, 05:12 PM
so different route
will a stock power steering just bolt right up?
i found everything i need to swap in power steering.
will i have any problems with the 1979 20r?
Old 06-27-2008, 05:58 PM
86tuning's Avatar
You need the steering shaft as well, it's an inch shorter than the non p/s one.
Old 06-27-2008, 06:58 PM
slacker's Avatar
forget what I said .. I wasnt doing hi steer ..
Old 07-09-2008, 10:47 PM
nico's Avatar
It takes about 2 hours to swap the manual steering box for a factory power setup. Everything bolts right up - no drilling or fab required. You will need the factory PS belt pulleys, too.
Zpd426
01-02-2016 01:15 PM
delmert
09-30-2015 04:34 PM
Up&Down
08-11-2015 10:04 AM
toyoterferdayz
Diesel Swaps
07-27-2015 05:25 PM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: histeer power steering for a 1979
