histeer power steering for a 1979
Hey everybody new to these trucks and need some help and advice
i want to to add powerstreering. and i figure lets just upgrade to hysteer has well. So what do i need, where do i get it and what works the best. my truck is a 79 4x4 with a 20r |
High crossover steering requires at least 3" of lift.
So if you have that then you need a high steer kit, ps pump etc, idler bracket etc, IFS box and mount etc. Let me know if you have any questions. :guitar: |
Originally Posted by waskillywabbit
(Post 50857154)
is there any one that offers crosserover for a stock rig.
i realy want power steering and want to do it right |
With ni lift, you could swap in a stock '79-'85 push-pull steering box. You need about 3" of lift for crossover steering to make room for the drag link to pass between the frame and springs. I ran ~3" lift with my '85 and it was tight fit adjusting the drag link to not hit the passenger side spring under full droop and yet stay off the frame at full compression. You might be able to notch the frame for less lift and/or run a Jeep style drag link where is runs down to connect the the tie rod under the springs.
so different route
will a stock power steering just bolt right up?
i found everything i need to swap in power steering. will i have any problems with the 1979 20r? |
Originally Posted by rottenagenda
(Post 50861540)
forget what I said .. I wasnt doing hi steer ..
(Post 50861540)
