Pre 84 Trucks 1st gen pickups
Old Feb 10, 2015 | 10:46 PM
  #2801
ToyTrucker's Avatar
Originally Posted by dropzone
Make sure you pull the rear driveshaft when you town it (unless it is on a trailer)
The transfercase doesn't get lubed correctly, I destroyed a transmission when it went into gear some how..
That truck is a 79-81..
Thanks and ye'a I always flat bed them. Thanks for the reminder but I never dolly cars.
Old Feb 11, 2015 | 04:41 AM
  #2802
81 Toyo's Avatar
Look under the hood to narrow it down.....if its got the 22R its a 81.....20R its either 80 or 79......the data plate inside the door will also tell you year of mfg....nice stock find....
Old Feb 11, 2015 | 12:49 PM
  #2803
jimbyjimb's Avatar
1982 sr5
Original 22R bottom end with 195k miles; 20R head with mild port work, OS valves and special undercut; Weber 38/38; LCE street performer cam. I don't like headers, so I use the factory manifold and welded my own 2" straight-through exhaust with side-exit just in front of the driver's side leaf shackle. Factory AC was recharged and works fine, though I need a new belt. Isn't even remotely comparable in terms of power vs a stock 22R. Next rebuild the top end will see even bigger valves, serious port work and an LCE mild stage 2 cam. As it is, it purrs like a kitten with a nice, smooth idle for the cam size. Fuel economy ranges from 15-18 average.
The wheels are Boyds. The rear bumper is a later model off of Eddie Vedder's 2wd truck. He replaced his bumper with a flat-black customized one so now my truck blasts Pearl Jam in the back. I have Rampage H4 lenses up front with super bright Sylvannia bulbs and a Putco headlight harness. I also put in a nice bright LED interior bulb. I replaced all of the visible exterior body screws/bolts/nuts with stainless. This was a camper hauler at one time, so that's why it has the tie-downs on the box.
It also has a custom 24 or 26 gallon fuel tank. Can't remember what size. I run the stock mechanical fuel pump sans regulator and have a backup electric ONAN 2.5psi fuel pump on the passenger wheel well. The backup pump only needs one wire to hook up and to connect the fuel lines. I used this ONAN pump sans regulator on a 20R for years. They're cheap, quiet, simple and reliable. If anyone ever needs it I can rattle off the P/N.
Old Feb 11, 2015 | 10:04 PM
  #2804
Jbowls's Avatar
I refer to her as the one who got away...
22r 4 speed locked front and rear
1982
Old Feb 21, 2015 | 09:58 PM
  #2805
ToyTrucker's Avatar
It's a 81!
Old Feb 22, 2015 | 05:28 AM
  #2806
81 Toyo's Avatar
Originally Posted by ToyTrucker
It's a 81!
Cool!.....Ive got the same original brochure with my 81.....its always nice when you get the original paperwork with a truck.....so what are your plans for it?....
Old Feb 22, 2015 | 10:27 AM
  #2807
86toyotaprerunner14's Avatar
Originally Posted by steveco.
heres my 80' p/u it has a 20r bottom with a 22r top with a holley TBI fuel injection setup. L52 tranny, Marlin crawler dual ultimate setup, 5.29 front and rear with a spool in the rear and LSD in the front. has disk brakes in the rear. the bed is bobbed. and too much other mods to list....
can we get some pics of under the hood
Old Feb 25, 2015 | 09:16 PM
  #2808
cjskeen14's Avatar
Originally Posted by lowfrankie
my 83
did u make those tube doors yourself?
Old Feb 28, 2015 | 12:55 PM
  #2809
pirate's Avatar
Great looking rig!!
Old Mar 5, 2015 | 11:15 AM
  #2810
localfiremedic's Avatar
Bunch of nice looking yotas
Old Mar 5, 2015 | 12:00 PM
  #2811
muddmadness's Avatar
That's a good one
Old Mar 5, 2015 | 05:30 PM
  #2812
Arkansas Jack's Avatar
Bought this new just restored<br/>
Old Mar 6, 2015 | 05:02 PM
  #2813
Terrys87's Avatar
Great looking truck. Just dont get to see to many clean first gens.
Old Mar 8, 2015 | 12:55 PM
  #2814
jimbyjimb's Avatar
This is the way I want to go as well. Frame off and add the roll bar. Ever since I saw back to the future the roll bar has been a must
Old Mar 9, 2015 | 01:37 AM
  #2815
ToyTrucker's Avatar
Thanks Toyo,
Clean her up, get a lift kit and possibly start taking the body off the chassis for some welding and cleaning up then paint.
Old Mar 10, 2015 | 11:34 PM
  #2816
dropzone's Avatar
Fossilized
This is BS. Can't believe they have the guts to ask $1500 for this total piece of crap
they should pay my airfare to Australia and to ship it to the US just to get it off the road
Stupid government keeping stuff like this off the roads of the US. I mean a $50 customs fee would be reasonable right
Old Mar 11, 2015 | 04:51 AM
  #2817
kawazx636's Avatar
Robb, If you really wanted to buy it I could get you some help with the logistics. My father-in-law lives a couple hours south of Brisbane and has shipped vehicles to the US before.
Old Mar 12, 2015 | 03:14 PM
  #2818
cjskeen14's Avatar
bad day for the yota. I was working on the floor boards in the cab. I hopped out to go cut the steel plates and as I climbed out my classmate started his ford ranger (smh) in first gear, with no brakes hooked up, and was sitting sideways with his feet out the door.(I guess he dident think to hit the clutch) and his oversized brush bumper rammed the ass end of my frame. at this time my driver side was on jackstands in the front because I was working on brakes so it just pushed it right off.
Old Mar 12, 2015 | 03:19 PM
  #2819
cjskeen14's Avatar
the truck kept on slidding in to the office wall and bent the front end right up against the motor, cracked windshield, bent hood, bent crossmember, door doesent shut properly*(possibly bent frame?)but no one was hurt and i would have been in the cab if it happened a second earlier.
Old Mar 12, 2015 | 05:55 PM
  #2820
dropzone's Avatar
Fossilized
I would love to do it but I would need to research the customs logistics before I pursued it.
