Pre 84 Trucks 1st gen pickups
Drain Plugs... They're all stuck
Old Feb 27, 2012 | 02:10 PM
Bingle's Avatar
Drain and refill should do, depends on how nasty it is I guess. If it was WAY bad I might run the cheapest stuff I could find for a little while, drain and put in some good stuff. I run all synth in everything in my '81 and have been very pleased but I flog it pretty hard so it's minor insurance.
Old Feb 27, 2012 | 02:31 PM
83Toyota88's Avatar
Define if its "WAY" bad. Like color or texture? Both?
Old Feb 27, 2012 | 04:38 PM
83's Avatar
83
Super dark and thick. Foamy is not good. Lot's of little metal shavings, not good. Some metal shavings might be normal, but a lot is not, and chunks are not good.
But yeah, if you've got a manual tranny, changing the fluid is a good thing, and the sooner the better. If you drive it around and get it nice & warmed up, you should be able to get the crap out without worrying about flushing.
Also, beware hijacking someone else's thread. You can start your own if you have a lot of questions.
Old Feb 27, 2012 | 06:16 PM
ledzeppelin3270's Avatar
This is what I took out of my axles. I'd say that's pretty bad! I used an air compressor to blow out the diff, seemed to work well.... there was no way that this stuff would have dripped out on its own.
Old Feb 28, 2012 | 08:18 AM
  #25
Boon's Avatar
wow.
mine wasn't quite this bad, but i did notice a change in both drivability and mileage.
Old Apr 13, 2012 | 06:54 PM
  #26
Pumpkinyota's Avatar
I went to the Quick-Lube, and laughed the whole time as they fought the plugs for 2 hours with an extractor. Best hundred bucks I ever spent.
Old Jun 1, 2014 | 12:40 PM
  #27
yay1904's Avatar
drain plugs stuck ?
I had the same prolem a couple times I found the only way to get em unstuck is to use an air impact wrench should come right out good luck!
Originally Posted by ledzeppelin3270
Today I wanted to change diff, transfer, and transmission fluid, but when I crawled under, I could not get the drain plugs or the filler plugs off I've got some Rust Bomb soaking on them right now and I'll take some heat to them tomorrow, but I was just wondering if anybody has encountered a similar situation and has any tips. Also, if anyone knows where I can get replacement plugs, that would be nice. A brief visit to the O'Reilly website didn't turn up any, and I would really like to replace them. Thanks!
hiluxinargentina
Sep 30, 2015 05:51 PM
Boomer8404
Sep 17, 2015 07:59 AM
gp66
Sep 14, 2015 12:10 AM
Boomer8404
Sep 10, 2015 09:01 AM
bootscootboogie
Sep 5, 2015 05:57 AM
