Pre 84 Trucks 1st gen pickups
81 pickup multiple questions
Old Feb 22, 2015 | 03:39 PM
  #161
4Crawler's Avatar
Originally Posted by parkerst02
How can you tell what transmission you have I don't see any numbers on it
Marlin's transmission page has a good ID guide:
- https://www.marlincrawler.com/transm...built-complete
Old Feb 22, 2015 | 05:50 PM
  #162
parkerst02's Avatar
W56 what is the difference between c d and e
Old Feb 22, 2015 | 06:04 PM
  #163
4Crawler's Avatar
Not sure, there is likely some minor internal difference that maybe only Marlin knows. Model year will tell you what is should have been:
- https://www.marlincrawler.com/tech/t...ar-ratio-chart
I had a W56A in my '85 originally and had a rebuilt W56B installed and it fits and works fine.
Old Feb 22, 2015 | 06:27 PM
  #164
parkerst02's Avatar
Well I don't know the year model of it but do they have reverse synchronizer or what would make reverse go out
Old Feb 22, 2015 | 06:39 PM
  #165
4Crawler's Avatar
Normally manual transmissions are non-synchromesh in reverse:
- http://en.wikipedia.org/wiki/Manual_...ission#Reverse
Not sure on the W56, but it is likely non-synchro in reverse. Could be any number of things causing reverse to not work. Likely all would require opening up the transmission to diagnose the problem, although a good transmission guy might be able to figure it out externally.
I had a problem with 2nd gear on my rebuilt W56B. 2nd gear slipped out of position on the shaft and caused to to be nearly impossible to shift into. The guy at the shop hopped in and he actually made it shift fine, but said the gear had slipped. Some of the gears are tight interference-fits on the shafts and if the gear bore is too large for the shaft OD, it will not fit tight enough and will slip, like mine did. They pulled the tranny out, cracked it open and pressed on a tighter 2nd gear and it has been fine for 16+ years now.
Old Feb 22, 2015 | 11:09 PM
  #166
parkerst02's Avatar
Okay that helps a lot thanks. I just thought it seemed like a synchronizer was stripped because it pops right out of reverse and I've already began tearing into it to find out what it could be
Old Feb 26, 2015 | 07:19 AM
  #167
parkerst02's Avatar
Where could I get a reverse gear for a w56c at
Old Feb 26, 2015 | 08:59 AM
  #168
parkerst02's Avatar
My bad it's a reverse idler gear that I'm looking for
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
