Stupid cone washers, on solid axels
Is there a special tool, or a reasonable way to remove the split/cone washers on the solid axle hubs and knuckles. I usually end up beating things around with a large hammer, and a very small screwdriver. (not a good match) Maybe Toyota has a special tool, or Snap-On? Has anyone invented one they would like to share?
Some ideas:
- http://www.4crawler.com/4x4/CheapTri...eWasherRemoval
And note that I have never run into one technique that will work with every single cone washer. All depends on what it holding it tight. So if you try one technique and get say 4 of the washer off, but 2 won't budge. Try something else on them. I have had some that literally fly off with the slightest tap of a hammer and others that are stuck on the stud and no amount of hammering will make them move.
I have taken off hundreds of cone washers and it is pretty easy.
Patience and know how. Not everything in life requires brute force.
Nothing sickens me more than to see a set of abused steering arms or manual hubs removed by an obliviot.
Clean the area of mud and debris.
Apply some lubricant like PB Blaster
Use a brass drift and a hammer to TAP, not beat the ever loving crap out of, on the stud and surrounding areas
Use patience and work around
If one wont come off immediately try another
Once one is off the rest loosen up quick
Never any need to get abusive with the hammer
Never any need for heat
Work smart not hard.
I used my brick hammer when I took mine off. It's got a square, flat head, and is offset from the handle about 3 inches. The head went right over the top of the hubs. I just had to hit the end of the stud a couple of times, just tapping, not hard, and the washers popped loose.
Other than that, Wabbit is right on
I use an air chisel to remove mine. Your probably thinking I'm an idiot but it works great if you do it right.
I just thread a bolt onto the stud part way so its like a dish and protects the threads. Then I use the pointed attachment on my air chisel and give the end of the stud a quick zap and the washer pops right off.
I've done it many many times and have never damaged anything.
I just figured this out. I threaded the nuts on the ends of the bolts, used a little muscle, some determination and allot of focus.
See Also:
http://www.barneymc.com/TOY_ROOT/TECHNEEK/conewash.htm
http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
See Also:
ashamsuddin
17
Jul 22, 2024 03:59 AM
TheBFA
Feb 15, 2020 06:55 AM
