Transfer case breather - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-18-2009, 02:03 AM   #1 (permalink)
During some research on the extension of the rear differential breather, I came across a lot of questions on a (possible) transfer case breather (with or without extension), but could not find any answers.
This afternoon I made some effort and found the breather, which looks the same as the one on the rear diff (also not extended); see picture.
Anybody experience with extending this breather? how long should the hose be to run it up to the engine compartment (next to the front diff extension)?
During my search I encountered a small hose that was worn and needs replacement (ductaped a for now). According to the repair manual it is a so-called breather hose that runs between the transmission side and transfer side. (see attachment). Anybody a recommendation what material to use for replacement? (size, length)?
What is the function of this breather hose?
Thanks in advance,
Sieb
transfer-case-breather-transfer-case-breather.jpg   transfer-case-breather-transfer-case-breather_location.jpg
__________________
4Runner Canadian Base Model; 2.7L; 4WD; Manual Transmission; 2002.
Engine: 3RZ-FE
Foureigner is offline
Old 09-18-2009, 03:27 AM   #2 (permalink)
drew303's Avatar
find the same size vac hose at your local auto parts store. As for the function, specifically I'm not certain what the engineers had/have in mind on that newer stuff. I'd imagine its to vent pressure between the Tran/Tcase to keep them equal.. a breather (as you found at the top) is designed to allow pressure out easily but not so easily in but not sure about the hose... something new i guess
__________________
1987 Pickup, single cab, 22R, new head, 260 cam
TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac.
drew303 is offline
Old 09-18-2009, 03:29 AM   #3 (permalink)
drew303's Avatar
unless only one case is truely vented... then they put the hose in place to allow for only one breather vent?
dunno..
__________________
drew303 is offline
Old 09-27-2009, 03:18 AM   #4 (permalink)
I think you are right; the hose functions as a breather for the transmission side through the transfer breather.
The hose was torn and I found the hose of kind of an inferieur material, if you think it needs to function as a breather and keep water and dirt out of the transmission and transfer case. It does not have a clamps, but just sits and the two nipples.
I replaced it with a much thicker and stronger hose and used clamps to secure. I think it is worthwhile checking.
See attached picture.
I am still wondering if anybody has extended the breather?
Thanks,
Sieb
__________________
Engine: 3RZ-FE
Old 09-28-2009, 01:28 AM   #5 (permalink)
sorry noob question but kinda on the same topic and id thought id post here.
does extending the rear diff breather do anything? other then help so water doesnt go in when you go roading and all taht?
i mean please dont flame my question just out of curiousity if it does anything else.. power? smoother? haha thanks
awpsome is offline
Old 09-28-2009, 04:01 AM   #6 (permalink)
KZN185W's Avatar
just preventing water/mud from getting into the diff.. no performance increase
__________________
1996 Pearl White Hilux Surf KZN185W SSR-G l 3.0L TDI l Dual Battery l LT285/75R16 l Recaro Seats
Drive Your Dreams
KZN185W is offline
Old 10-10-2009, 07:50 PM   #7 (permalink)
cheap insurance
some have suggested that extending the diff breather to a cleaner location higher up on the body helps the pressure within the diff and extending life of the seals.
Not sure all that is true, but it's cheap insurance for some tubing and a vent and 15 minutes of time. I did it and it was piece of cake.
__________________
99 4Runner SR5 4wd 3.4/5 spd-
Fact. Rr. Locker/Diff Breather Ext.
Old Man Emu lift springs- 881 fronts/890 rears
O/M/E shocks- N91s fr./N86 rr.
All Pro Off Road welded sliders-prevent body damage!
ARB"Taco"bumper/Gamiviti clear lenses/Hella 500s
Redline Tuning hood struts/Bushwacker Extend a Fenders
all my photos are over on Facebook now-I gave up on photo hosting sorry....
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline
Old 10-16-2009, 09:54 PM   #8 (permalink)
What do you guys think of the solution used by a FJ cruiser owner for the differential breather and the transfer breather?
http://www.fjcruiserforums.com/forum...ather-mod.html
__________________
Engine: 3RZ-FE
Old 11-07-2009, 07:14 AM   #9 (permalink)
I like the general premise Foureigner-tie into existing breather lines and so on.
but not certain how much of that is applicable to a 3rd gen Runner
Tags
breather, function, hose
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
