Optima Red-Top Slowly Dying
Arg, so my 4Runner had been having some VERY slow cranking starts, it's literally getting worse by the day. Tomorrow, I fear I will not be able to crank the engine over so its time to get a standard replacement batt at Autozone.
I have an Optima Red-Top 34R but a few months ago it slipped out of the battery hold-down and ground against the power steering pulley, making a small hole in the case at the bottom (those Optimas are slippery little bastards). Everything seemed to be working fine, but now the battery can't seem to hold much of a charge overnight, and I'm guessing this hole is to blame (nothing really leaked out of the battery, it just has some acid build-up on the hole like you would see on the poles with a standard acid battery.) Probably some gases slowly escaping, making it hold less charge each day. In retrospect, I should have JB-Welded the hole shut... damn 20-20 hindsight.
I know what you're thinking, and yes my alternator is working fine. I have an MR2 alternator and an aftermarket digital voltage gauge, it cranks out 14.4V at anything over 750 rpm.
Anyway, this is more of a rant than a thread asking for advice, and I would buy another Optima since they are great batteries but I'm selling my 2nd gen in about 2 months so no need to buy a REALLY nice battery for the 4Runner. Just thought I'd let you guys know, crank that Optima down or it could be damaged by your pulleys (or visa-versa)
In retrospect, any stadard battery would have leaked all of its acid out and stopped working on the spot, so really the Optima held up admirably.
Originally Posted by 1styota4X4
It should be under warranty 3 year free replacement...where ever you bought....if its autozone just rant and rave enough and they should replace it its there policy
I bought it at Batteries Plus, maybe I'll try finding one and give them a call. Thanks dude
Is your Red Top a Deep-Cycle/Starting Battery???
Because I have a Yellow-Top in my 4Runner and its a battery designed for Starting as well as deep-cycle!! But A battery will take a good 2 hour drive to fully charge up after a discharge like that!!
Red-Tops are not deep cycle, to answer your question. Also strange, is if I have been driving around for a little bit and turn the car off, it will start rioght back up. But if it sits for a few hours it seems the battery begins to lose its charge, and after a whole night it barely has enough juice to start the car. This morning the battery registered 11.1 volts before I started it, but the previous evening it had 12.4 volts. I also have checked to see if there are any lights on or anything that might be discharging the battery, and nothing has been left on.
It's just finally giving out I think, barely holding any charge. I'm going to buy a cheapy $60-70 battery, and then see if I can get the Optima warranteed, which like I said I doubt because it has been damaged.
Originally Posted by TNRabbit
ALso, you may be due for a starter contact rebuild (kit from the dealer for $15)...
Originally Posted by Mikestang
I burned through 2 red tops in my mustang. Once they lose their charge they're dead. I'll never own another red top. I'm going to try a yellow top in both the stang and the 4R.
http://www.odysseybatteries.com/
I'm thinking about doing a dual battery set-up on my new 4Runner, perhaps dual yellow-tops. We will see, that's farther down the road...
Wow, same EXACT thing happend to my 92 4Runner with a red top. A few months after the damage it started sucking, I had it tested, 1 out of the 6 cells was dead.
Soultion, new red top and something better than a bungee cord!
Lamm
Lamm
Lamm
Lamm
Yeah, stupid battery hold down.
Steven.m.paulk
Jun 7, 2020 10:45 AM
