Underdrive Pulley? N/A and Supercharged? 7-14HP cheap
Old Sep 29, 2005 | 06:22 AM
JimmyK's Avatar
Hi guys I did a good search on this forum found some solid discussions saying how it WOULD be great but at the end nothing ever came of it. It seemed everybody agreed it was a great idea but it never came to fruition, any reason why not?
I wanted to upgrade my UDPs I already have a s/c with a 2.2 pulley so I figured somebody on this forum with my setup MUST have upgraded UDPs to yield better performance.
cheers
Old Oct 8, 2005 | 12:45 PM
JimmyK's Avatar
hey I just found an underdrive pulley from URD, has anybody tried this? and what the heck is acceleration horsepower does that mean at the crank?
and if that little mod will yield almost 10HP I think its well worth it.
Old Oct 8, 2005 | 01:28 PM
rimpainter.com's Avatar
The big debate on crank pulleys always ends up being balance and the bottom end of the motor. Some have found that a UD crank pulley significantly reduces the life of the motor. Take an H22A prelude motor for example. There is a guy that tore his motor apart after installing one and found significant wear on the main bearings...but that's a lude.
In all honesty, I have no idea about the 5VZFE and harmonic balancing. Sounds like it needs to be re-visited. Are you talking about a full accessory pulley set, or just the crank pulley, or what?
Old Oct 8, 2005 | 07:13 PM
JimmyK's Avatar
I would be just focusing on teh crank pulley because that is mainly all I can find, plus that has the biggest mass by far. If I remember correctly arent our 5VZFEs internally balanced? So it wouldnt impact bearing wear or any type of engine balance issue? Im also not the most educated thus my post
Old Oct 8, 2005 | 07:14 PM
JimmyK's Avatar
here she is FYI
http://www.urdusa.com/product_info.p...e5585968036d3f
Old Oct 8, 2005 | 07:43 PM
marko3xl3's Avatar
Basically, the smaller your pulley, the more heat you will create which will in turn cause your engine to wear faster.
Now if you are willing to spend money of an Aquamist system, it becomes a totally different story.
Good Luck!
Old Oct 8, 2005 | 08:21 PM
jimbo74's Avatar
the 22rs and 22res have used underdrive pulleys for years on lce motors....
Old Oct 8, 2005 | 08:35 PM
TRDOLMAN's Avatar
Who told you that pulley from URD was an underdrive pulley?? It is NOT. It IS a lightweight pulley but it is not smaller. It IS set up like the supergrip S/C pulleys in that it aids with belt slip.
Dave
Old Oct 9, 2005 | 07:53 AM
JimmyK's Avatar
Nobody really told me it was my assumption - sorry I may have used the wrong wording. From my understanding an aftermarket UDP was either one of the two or both --Lighter or smaller-- / --lighter AND smaller--. So I may have been wrong in terminology but once again back on track; Has anybody used it in their 3rd gens with their 3.4s and found it a worthwhile and dependable upgrade?
As Jim said it seems to have worked on the older 22s which is a good sign, thanks for the input!
Old Oct 9, 2005 | 09:11 AM
kyle_22r's Avatar
there are much better, safer ways to gain horsepower...
Steven.m.paulk
Jun 7, 2020 10:45 AM
moparbay
Oct 6, 2015 09:24 AM
Obmi
Oct 4, 2015 11:30 AM
LCE_Performance
Oct 1, 2015 01:03 PM
