Does anybody know what those connections are?
Old Apr 3, 2005 | 07:17 PM
YotaJunky's Avatar
Hi all,
I just replaced my rad with an aftermarket one.
https://www.yotatech.com/forums/f16/radiator-replacement-how-pics-55979/
The aftermarket rad came with these 2 pipes near the bottom of the rad which are plugged up with rubber stops. I don't know what they are for and the rubber stops seem kind of thin and flimsy. I was thinking about connecting a hose between the two ends to circumvent any possibility of a leak, but I'm not sure if it will damage the rad in any way.
Any suggestions?
Old Apr 3, 2005 | 07:20 PM
SoCal4Running's Avatar
They are for automatic transmissoin cooling.
Old Apr 3, 2005 | 07:23 PM
YotaJunky's Avatar
I've got a manual tranny. I specifically ordered the rad for manual tranny and it looks like they have given me the wrong one. Anyway, it's now installed and I want to make sure that I don't have any leaks coming out of one or both of those pipes. Those rubber stops just don't look like they are going to last.
Any suggestions?
Old Apr 3, 2005 | 07:25 PM
It'll be fine, I think they ALL have the connections for the auto cooler. But to be safe you could run a hose straight between them.
Old Apr 3, 2005 | 07:28 PM
YotaJunky's Avatar
The old Toyota rad I took out didn't have those pipes. I guess it's just more cost effective for the aftermarket crowd to put them in and sku them for both manual and auto trannies.
So running a hose straight between the 2 will not interrupt flow if the stops are removed? I guess I could leave the stops in place and run a hose between them with clamps for peace of mind ...
Thanks for the suggestion.
Troy
Old Apr 3, 2005 | 07:31 PM
Actually there is no flow inside of them. It is a separate passage thru the radiator for the transmission fluid. Coolant will not leak out with the caps off, the reason for the caps is if you do not have an auto tranny and the connections are not used they will keep water and crud out of the passage that could cause corosion. Either leave the caps on or use a hose between them.
Old Apr 3, 2005 | 07:34 PM
shimonmor's Avatar
I wouldn't bother with a hose. Nothing can leak out of those fittings. Those fittings allow ATF to come from the tranny, be cooled in the rad and then sent back to the tranny. With nothing hooked up there is just air in their. No coolant will come out unless an internal leak develops which is unlikely. The rubber stoppers are there to keep dirt from getting in.
Old Apr 3, 2005 | 07:36 PM
YotaJunky's Avatar
Excellent! Thanks for the info. I feel much better now knowing that there is no coolant flow in that part of the rad. I'll leave the caps in place. Since there's no pressure build up in there, there's little need for a robust cap. That explains why they looked so flimsy.
Thanks to all for your help!
Old Apr 3, 2005 | 07:43 PM
jimbo74's Avatar
the plastic caps fell off mine... and mine is an aftermarket unit... i did order it for a manual tranny... the part numbers are the same.... its actually this way on most vehicles with auto.manual trannies
Old Apr 3, 2005 | 07:46 PM
YotaJunky's Avatar
Yours fell off? Maybe I should reconsider putting that straight hose between the two pipes! lol...
Old Apr 3, 2005 | 07:53 PM
jimbo74's Avatar
the plastic plugs on mine fell off, it doesnt matter though... they dont do anything... all that is in there is air..... if you will feel better about it, put a hose, its just not needed the space in there is empty
Old Apr 3, 2005 | 07:55 PM
DudeBud's Avatar
they dont need to be capped i have left mine open ever since I got it almost 3 years and everything is fine. you could just cut them off if they bug you
Old Apr 3, 2005 | 07:59 PM
YotaJunky's Avatar
ha.. ha.. these rubber stops have been beaten to death!! I'll leave 'em be... The aftermarket rad has got a lifetime warranty, and if the caps fall off and rust out the bottom of the rad, I'll just get another one!
Old Apr 3, 2005 | 08:23 PM
Scooter22's Avatar
My aftermarket radiator has those connections also and I never knew what they were for.
troy65 nice writeup on the rad install.
Old Apr 3, 2005 | 08:52 PM
YotaJunky's Avatar
Thanks Scooter22. I'm just giving back to this community which helped motivate me to do my own repairs. Also, it's a good ego boost.
Troy
Old Apr 4, 2005 | 12:40 PM
YotaJunky's Avatar
Well, I just slapped on a couple of cheapo clamps and that should be it. That'll keep the bottom from corroding.
Old Apr 6, 2005 | 10:11 AM
YotaJunky's Avatar
Here's a quick shot of the clamp on one side. This will ensure that it doesn't fall off and cause rust in the bottom of the rad.
Steven.m.paulk
Jun 7, 2020 10:45 AM
puddlepirate
Sep 29, 2015 08:02 PM
voiddweller
Sep 28, 2015 11:21 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
