Any TIG welders in the group?
I love my new finger tip control on my TIG torch! If you are still using a foot pedal control you have got to try one. I feel like I got rid of a ball and chain around my leg.
really i heard about those, can u control the amperage with it? i bet id be nice to weld away from the table and use it like a mig gun on other things, is it a weldcraft torch and watercooled ? ill have to look into it
Yes, it controls the amperage and turns the gas on and off just like the foot control does. I just have the torch that Miller supplied with the Econo-tig. (Weldcraft, not water cooled). I bought it not sure how hard it would be to control but it is actually easier to control the torch now. Just having the switch strapped onto the torch gives me more leverage and a better handle on the torch. But the real benefit is not having to drag that foot pedal around every time you move to another position. I guess if you are just sitting in one spot at a bench and welding something small the foot pedal is better, but I have been welding things that require I stand up and move around it and the foot control was just like a ball and chain around my leg. Now I can TIG weld sliders to my frame while laying on my back under the truck.
The finger control is expensive ($160), but as long as it lasts a long time it will be well worth it.
Here you go Cebby: http://community.webshots.com/photo/...10422335cIQkCg
The control wheel is on the other side too. So if you like to switch hands, like I do, you can use your left or right thumb on it. It is just backward when you switch sides, like left-handed the dial turns off moving your thumb up and right-handed you move your thumb down to turn it off.
Yeah Cebby it looks like your's takes the same one, (RCCS-14 Part # 043688), a 14 pin connection. Here is where I got mine: http://www.jandrweldingsupply.com/st...rowave180.html
Look down on the accessories list for your Syncrowave 180. Count your pin holes on your foot pedal plug just to make sure, Miller also makes them for the older 5 or 6 pin plugs too.
Originally Posted by BruceTS
I just recently bought a Synchrowave 180 SD (newer model), looks like I'm gonna have to get the finger tip controller.....
(I really didn't know the age of mine...)
Here's a shot after I got it out of the box
Is that in your kitchen? That sucker is damn heavy, I can tell you that...
Here is a pic of the 14 pin connector from my foot pedal control: http://community.webshots.com/photo/...11050427ENVtbO
Thought there might a little confusion since there is actually only 5 pins used on the 14 pin connectors. My Econo-tig was bought back in 1997.
TheBFA
Feb 15, 2020 06:55 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
