Climate control panel bulb s14w
I don’t know if the Climate panel is the same as a 91 but this fit my truck, I tried the single LED that faces forward and it didn’t reflect through the plastic panel left and right and had a major hotspot, so I went with the 3 led one and used I little butyl to block the front facing bulb, on the plastic not the bulb(if that makes sense) it works great, very bright and even. But again this is on my 91……superbright bulb number is just type 74…..
The specs are on the site, I’m sure you can measure your old bulb and see if the dimensions will work.
https://www.superbrightleds.com/74-l...ure-wedge-base
I have found the correct bulb!! Thanks to a previous post titled 87 HVAC Control Switch Bulb... The correct bulb is Sylvania 2721. Thanks to that sub and thanks to those who offered suggestions!
Dawsonmarch
Feb 26, 2024 04:02 PM
GrimWolf
May 20, 2019 07:03 PM
crappled
Oct 25, 2005 10:29 AM
