Climate Control Lightbulb
Old Jan 31, 2005 | 01:59 PM
Steveh29's Avatar
The lightbulb behind the climate control panel in my 1995 4Runner burnt out. This is the panel where you turn on and off the heater or AC. It's the green light bulb that illuminates the whole panel. I tried to buy a new one but the dealer says I have to buy the whole climate control assembly! I tried using a bulb for the instrument panel but that bulb is smaller and won't work. Anybody have to deal with this problem? I was thinking if push comes to shove I could use a green LED but that won't dim like a regular light bulb will it?
Old Jan 31, 2005 | 03:29 PM
jahMcS's Avatar
Steveh29, I'm going to change out the whole switch assy. The bulb still works, you can have the bulb. I hope to do it this weekend. I have a 90 V6, I think it should work.
Old Jan 31, 2005 | 03:49 PM
Steveh29's Avatar
Schweet! Thanks a lot! I'll PM you my address.
Old Jan 31, 2005 | 06:35 PM
Dublin's Avatar
What kind of a Toyota stealership did you go to? Its a sylvania 74, the same lamp used for the glovebox light, ashtray light and climate control light. If they don't have one any GM stealership will. You could also try NAPA or Autozone, its a pretty common lamp.
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
toyotasaurus
Sep 24, 2015 03:30 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
87SR5justin
Sep 15, 2015 06:48 PM
