1989 4Runner rear window not working
Old Jan 20, 2021 | 08:21 PM
Jakeboy's Avatar
Problem with 1989 4Runner rear window not functioning. Checked motor is good. Bypassed safety in tailgate. I can hear relay activating inside doors panel. What should I check next?
thanks
Old Jan 20, 2021 | 11:32 PM
mholme's Avatar
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old Jan 21, 2021 | 05:03 AM
wallytoo's Avatar
thanks
you should search yotatech for the answer. there is no relay in the rear door for opening/closing the window. that is behind the driver seat, inside the trim panel.
Old Jan 21, 2021 | 09:13 PM
RAD4Runner's Avatar
Start with simple and free things, and one step at a time.
Disconnect connector to rear window wiper. This will disable "wiper not parked" interlock. Then tell us what happens. This is a free and simple test.
Old Jan 28, 2021 | 07:43 AM
4runnerx3's Avatar
Are all the bolts in on the left side holding the top on?
Old Jan 28, 2021 | 07:46 AM
4runnerx3's Avatar
Is the top bolt in that pushes on the switch? Window lock turned on?
Old Jan 28, 2021 | 10:20 AM
RAD4Runner's Avatar
How Rear Window Control Works:
https://www.yotatech.com/forums/f116.../#post52399326
Alex Aerts Jr.
Mar 29, 2018 08:32 AM
derockus
Nov 3, 2013 06:13 PM
slamb478
Jul 28, 2008 09:09 PM
sdoolin
May 9, 2008 04:27 PM
doc76239
Aug 6, 2006 05:27 PM
