Starting Problems
Old Jan 23, 2020 | 05:37 PM
Taube94's Avatar
Starting Problems
I have a 87 4Runner that’s been sitting for several years. A fresh battery, draining fuel tank, blowing out the fuel lines, fuel pump, fuel filter, spark plugs and wire I can get it to start and running for a second and then it dies. I was thinking it might be a timing problem but wanted to ask someone else’s opinion.
Old Jan 23, 2020 | 07:23 PM
scope103's Avatar
Welcome to YotaTech.
"Start and run for a few seconds then dies" is the classic sign of a VAF-COR problem. And it's the easiest to diagnose. Jumper FP to B+ in the diagnostic connector (this forces the fuel pump to run with key-on). If it runs now, you have a problem in the VAF-COR circuit.
Old Jan 24, 2020 | 05:33 AM
Taube94's Avatar
I tried and same problem.
Old Jan 24, 2020 | 01:42 PM
5 Fists's Avatar
Does your pump come on? I know you said you drained the tank, blew out the lines, replaced the filter and pump, but are you actually getting fuel after doing all of that? You're getting spark if it's firing up, so it's no air or no fuel stopping it from continuing to run I would think.
Old Jan 24, 2020 | 02:22 PM
scope103's Avatar
The "easy" way to check whether the pump is moving fuel is to replace the fuel return line from the FPR with 6mm/1/4" vinyl tubing, place it into a suitable container, and run the fuel pump with FP to B+. There is no spec, but I get about 1/2 liter/min. If that "test" passes, try to start. If the fuel flow cuts off, you may not have enough flow out of the pump to hold the pressure in the rail.
(The fuel return line is low-pressure, so you can remove and replace it with the hose clamp. The high-pressure connections are sealed with crush washers, which must be replaced each time they're opened. Why bother with that?)
Old Jan 24, 2020 | 10:44 PM
Austin92pickup's Avatar
Ok thanks
Old Jan 25, 2020 | 12:52 PM
RAD4Runner's Avatar
Happy New Decade and welcome to the forum... BUT
Originally Posted by Austin92pickup
Im having a similiar issue on my 1992 toyota pickup 3.0 v6.Starts then stalls.
Did you bother to do what have been posted above? The reason for this forum is for us to learn from others' experience.
Old Jan 25, 2020 | 01:28 PM
Taube94's Avatar
I haven’t had a chance to try yet. Probably tomorrow
Old Jan 27, 2020 | 08:59 AM
Taube94's Avatar
I tried what Scope13 said and got great flow.
Old Jan 27, 2020 | 10:40 AM
RAD4Runner's Avatar
... and did it fix the problem?
Old Jan 27, 2020 | 11:30 AM
Taube94's Avatar
No. Starts runs for a second and dies
Old Jan 27, 2020 | 11:53 AM
RAD4Runner's Avatar
This will help troubleshooting:
https://www.yotatech.com/forums/f199...l#post52312190
That's it?
Even if you keep on running the fuel pump with "FP to B+" ?
If you'd like people to help you from thousands of miles away, you need to let us see, hear, smell, feel what you're dealing with.
Old Jan 27, 2020 | 12:38 PM
Taube94's Avatar
I got to stay running while you hold the pedal but it will not idle
Old Jan 27, 2020 | 12:39 PM
Taube94's Avatar
Trying add a video
Old Jan 27, 2020 | 09:43 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Was it running ok just prior to sitting several years, or were there issues?
Old Jan 28, 2020 | 02:37 AM
Taube94's Avatar
it was my dads until he passed. He said the motor was getting weak but never really said exactly what was going wrong
Old Jan 28, 2020 | 07:31 AM
RJR's Avatar
RJR
Does the check engine light (CEL) work? It should come on when you turn the key to ON, but not START. If the CEL works, check for codes. That involves shorting a couple of pins in the diag connector (not sure which ones on an '87 - someone here can probably help) and counting flashes.
If the CEL doesn't work, fix that first so you can check for diagnostic codes. Diagnostics on these engines are not sophisticated, but can be helpful.
jsanders1972
Aug 8, 2013 04:04 PM
76 chinook
Dec 7, 2012 04:44 PM
A.Wilson013
Sep 10, 2009 05:36 PM
iwilder
Feb 1, 2008 05:58 AM
satexas
23
May 1, 2004 06:55 PM
