Passenger door window '84 4Runner
I have an '85 4Runner and my window stopped working from the passenger door only. Driver door can put it up or down. I replaced the switch and made sure the connections work.
What is the solution here???
On my '94, there is a switch in the driver's side to "lock" the switch on the passenger side (so it won't work). Make sure that switch (if you have it) is in the right position.
Otherwise, you need to work with a multimeter. Technically, that's the only way to "make sure the connections work."
You might get better responses in a different forum: https://www.yotatech.com/forums/f115/
wrenchtech
50
Sep 8, 2019 01:18 AM
RustRunner89
Jul 13, 2018 10:01 PM
mrvictory1999
Oct 18, 2017 01:25 PM
