Headlights go out on an 88 22re
Sometimes the headlights go out, the high beam indicator light comes on, I flick the light switch, and the headlights are back.
I went to an auto parts store to get a headlight relay. They said save your $30, the relay doesn't work that way, and that it's probably a small inconsistent short in the switch leaver mechanism or steering column.
Thoughts or experiences welcome...
Last edited by lululalalu; Dec 14, 2016 at 04:53 AM. Reason: The body of my post is not showing after I logout
this is likely the result of the factory wiring flaw by the toyota electrical engineers. all the current passes through the switch stalk, and burns the contacts. intalling a relay will help, but you'll need to take the switch apart and clean the contacts. there are posts/topics out there (here on yotatech and at t4r.com) detailing how.
wally
wally
Thank you wallytoo. If you are responding, I guess you can see my post. I rebooted and still cannot see it. I'll Ctrl+V below.
"Sometimes the headlights go out, the high beam indicator light comes on, I flick the light switch, and the headlights are back.
Thoughts or experiences welcome..."
Original post and Ctrl+V in my response are blank after multiple reboots. Weird. Lots of waiting for adds to load too. Admins, what's up?
I'll type my post again (rather than copy/paste from word) to see if I can see it.
Best,
Best,
Here is a link to a thread that may have helpful info:
https://www.yotatech.com/forums/f116...ndomly-295547/
oh, thanks to scope, i now see your text in the first post. if i use my "left mouse button" and select, it shows the text.
if you edit your post and change the text color, it should show up.
How I fix mine.... https://www.yotatech.com/forums/f199...l#post51724567
Your intermittent problem and high-beam indicator coming on while low-beam intermittently turns off point to the low-beam contacts. on the dimmer-stalk-switch. Do as Terry did to make sure contacts are clean and in good condition.
How does this happen?
When pins 6 and 13 of the dimmer-switch-stalk lose contact:
1) low-beam filaments lose ground so they turn off, AND
2) positive side of high-beam indicator gets12V through the low-beam filament so indicator comes on.
Schematic is here:
Thank you all for helping me post (I'm guessing the text color was black and not visible since I was pasting from word), and on identifying the stalk as a likely culprit.
I will break out the nail file and give the stalk a once over.
Best,
Best,
