SR5 gauge problems
SR5 gauge problems
I put an SR5 cluster in my 85 4runner
Volt and fuel gauge work GREAT so far
Oil and temp have the problems
Oil excites to the bottom of the line and the temp starts in the center. I have replaced the sending unit on the oil presser on the block (AKA the big one)
and have cleaned the off the temp unit on top of the water neck on the EFI!!
any other ideas would be great!!! Thanks
Not sure about the oil pressure gauge but the coolant temperature gauge is known for problems. Check what they said above^^, along with wiring. The gauge sender and the ECU sender are different.
I do know that both of those gauges share the same board inside the cluster.
For the coolant temperature gauge problem, check out this thread:
https://www.yotatech.com/forums/f116...ge-fix-271152/
I bought an SR-5 Cluster for my truck and have the problem mentioned in this thread, but I haven't gotten around to fixing my cluster yet, so I have no first hand experience to help you.
Good luck!
-Jake
Good luck!
-Jake
btu44
Oct 7, 2016 08:03 AM
