Shock absorber replacement for 94 pickup recommendations?
I'm overdue for shock replacement. I've ridden in pickups with ranchos and I don't like how stiff they are. I'm leaning toward bilsteins because of their longevity. I'd like a smooth ride which might be a lot to ask for with the 4wd's. Any recommendations? Will I be happy with bilsteins?
Thanks in advance.
Thanks in advance.
Is this for a stock height truck? The Gabriel gas a-just are pretty good and not too expensive.
How old are your springs/bushings? If the springs are whooped, they could be causing a lot of the harsh ride, new shocks will only help so much.
Good point about torsion bars and bushings.
Anything else I should replace to get it feeling new again?
Thanks!
It's stock. it's got 240k miles on it and I'm planning on getting tierods and bushings replaced. Didn't consider the torsion bars--they're original. I didn't know torsion bars wear out enough to give a harsher ride. I have idler arm replaced 5-10k miles back and steering rod (not sure of the part name) was replaced 7 years back on recall.
Thanks!
Been using Bilsteins on my 94 for a few years and am very happy. Berfore that, I had some other brand of shocks the previous owner had installed that were relatively new, but very stiff. The old shocks were KYBs, I believe. Couldn't sell them on Craigslist, so dropped them off at the local recycler.
https://www.1sttoyotaparts.com/oempartscat.html
Thanks!
Thanks!
Your t bars are fine, if anything they get softer as they wear. Control arm bushings may need to be replaced through.
infinityisfive
Jun 16, 2015 06:51 PM
markshoreline
Jul 31, 2002 11:05 AM
