Replacing oil filter bracket on '97 2.7 Tacoma
I looked all over the net for directions on removing and replacing the oil filter bracket. All I found were people asking others to post the directions. I'm no expert, but I thought my experience might help others. Let me start by saying this isn't an easy job due to cramped quarters. You'll need various socket extensions, including a wobble one.
1) I jacked up the front end of my Tacoma and removed the passenger side wheel.
2) I removed the oil filter through the wheel well, using a universal chain oil filter removal tool.
3) I removed the 2 bolts and 1 nut. The right bolt was very challenging, requiring a wobble extension and a lot of time to break it free.
4) I removed the bracket and cleaned it.
5) The O-ring wasn't about to come out of the shaft coming out of the engine, so I just used a razor blade to cut it.
6) I put silicone O-ring lube on a new gasket and O-ring and reinstalled the bracket.
7) I replaced the 2 bolts and nut and torqued them to 21 foot pounds. At least I did my best to do so. There was no way I could get the torque wrench in to torque the right bolt, so I just had to guess on tightness. Possibly if you have a helper you may be able to have one torque it from the top while the other holds the socket on the head of the bolt, though I didn't have a helper available to test this out.
8) I put on a new OEM oil filter, started up the truck and checked for leaks. It appears to be holding up fine.
What does a Solid Axle Swap have to do with an oil filter bracket? That's a lot of time and money just to have easy access to the bracket.
By the way, my truck is 4WD.
I can't see spending that much money just to make an occasional, not that difficult, chore a little easier. It reminds me of the saying "Penny wise and pound foolish."
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
dlotoy4runner
7
Jul 9, 2002 01:11 PM
