6-7 inch rear lift on ext cab pickup need longer driveshaft?
hey i was wondering if the driveshaft would bind with a 6 inch rear lift? if so would i have to buy shims. could you lower the carrier bearing by making some brackets? thanks.
got bj spacers and add a leaf in the rear, 3 inch body. now going to put in a 4 inch procomp stage 2 lift with blocks. i know the truck is too high for you guys but i dont wheel hardcore like you guys
got an issue. installed the 4 inch bracket lift but the front driveshaft doesnt angle low enough to hook up to the front diff. i took out the diff drop spacers and it still wont work.
6th Gear
19
Dec 10, 2019 07:31 AM
