odometer runs without truck moving?
I have recently swapped cabs on my 84 pickup due to a four wheeling accident and now when I start the engine the odometer starts rolling miles on while im not moving? Does anyone have any idea on what could cause this? Any input would help... Thanks.
Did you find the cause of the problem yet ? On a truck with a mechanical speedometer the only thing in there that can move the odometer is the speedometer cable. If it was an electronic speedometer it could be a short . Other than that I stumped.
So with the cab swap, what all was swapped? Was the speedo/odo the original one? If so, it should be mechanical, driven by the speedo cable out of the back of the t-case, unless someone swapped in an early '92 cluster w/ electronic speedo/odo. Check the cable out of the back of the t-case and see if it is a rotating mechanical cable or if it is the VSS (electronic sender) with a wire running from it.
James
WI Girl
Jun 25, 2015 03:45 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
saphirekosmos
Jun 22, 2015 10:26 AM
