Transmisson only works in 4L Help!
I have a 93 v6 auto trans pick up and I have had this problem for a few months, Sometimes I cannot get the truck to move and If I fiddle with the shifter or put it in 4L in will lockup and go. Yesterday I was driving in the snow and put it in 4L to go up a steep hill and when i stopped at the to to put it 4h it slipped so bad I couldn't get to go so I put it back in 4L and it worked fine. Today it still wouldn't go any where in 2H or 4H but is ok in 4L I haven't had time to check codes yet. But can anyone tell where else I might need to start looking. I assume the trans is probably ok cause it shifts and goes ok in 4L. any help would be appreciated
Thanks
Thanks
or you got some nasty slip that is being hidden due to the compounding torque after the convertor through the gearset. tranny doesnt have to work nearly as hard when it is pulling 2.5 times less in 4l
Just checked codes and everything is fine. I guess it's junk. I don't quite understand why it would go to crap by just going into 4 L and it won't come out of it. could it be any of the shift solenoids being stuck
dont know if this will help. when my trans lost first, it would pretty much slip, but still move, i used to get shudder...thought was the tires. but 4l still pulled the truck onto the flatbed without the winch. crappy thing is the transfer and trans are pretty mated on these things. find a trans shop you trust or find a nice donor trans after you've gone though a linkage check.
my bill was 2140 for full rebuild plus a new part in the transfer case that was looking tired
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
