Birfield Problem
Birfield Problem
I must be missing something, but as I have seen in every SA rebuild thread, the birfield is just supposed to come out of the axle housing. I can't get it past the knuckle bearings and out past the knuckle. From everyones pic's it appears that once the spindle is removed, it should come out. Well, I called it quits for the night before I get too mad at it and break something. Hopefully someone can help me, this has me perplexed.
Not sure what is going on. I would rotate the drive shaft back and fourth a few times. If it is past that point and out of the gears it should slide right out.
look here https://www.yotatech.com/forums/f152...31/index6.html It is the reverse of that or check this one.. https://www.yotatech.com/forums/f115...ctures-180536/
Thank god you answered, i was looking at your posting from 09 in someones thread, using it to figure it out.
Seems to be that it is hitting the outside edge of where the knuckle bearing holes are, like the ends are bent up, which by looking at the position of the holes is physically impossible. I tried yanking, pulling them out at an angle, everything, but they just wont come out! Im going to get in the shower real quick, the mrs wont let me sit on the couch, lol. I'll be back in a few and find a pic of an open axle with the birf still in it, i cant take a pic causei seran wrapped the axle ends, expecting rain tonight.
yes the flat spots have to be together and level if they are and you are still having problems it sounds to me like there is something bent like Etype r said.
Look at my second link from above you can see the flat spots in the pics those have to line up in order for the axles to come out.
WOW, I am an idiot, i didnt even see the flat spots. The 20th pic down in the second thread you posted up showed it clear as day. So, you want the flat spots on top and bottom, correct?
There are always things you could fuggle up if you use too much force. I would just be careful not to mar or dig a grove in the axle housing. You don't want your new rebuild leaking as soon as you put the grease and gear oil in there.
Sounds good, ill post up when (and if) i get them out, thank god Jonny is letting me borrow the third out of the 83, mine is gone, drained the fluid and guess what? Metal shavings and grey fluid.
WOW, you guys were right, lined up the flat spots, slipped right out. Took all of litterally 5 minutes. See, I should have posted up on here before taking the two hours to try and figure it out, once again, YT comes through! Thanks again Toyo and E TypeR.
