Birfield Problem
Old Mar 4, 2010 | 01:44 PM
seanmearse's Avatar
Got the third out too. Found out some interesting things too. The front is 5.29's with a locker! The question is, is the locker any good? If you put an axle shaft in it, it will turn the pinion and the other side. Its almost like its permanently engaged. I took some pics, maybe you guys will know if its engaged or not. Let me know what you think.
Old Mar 4, 2010 | 01:53 PM
broncrider's Avatar
thats cool that there was a locker in it. but like you said wonder if its any good. think it might be a ratchit locker or somerthing like that?
Old Mar 4, 2010 | 02:04 PM
seanmearse's Avatar
It definately is a ratchet style, like a lock right or something. Im just wondering if its in the right position and not locked. I'm hopefully trading it to jonny for his stock 4.10 diff in his 83, I just dont have the money to regear the rear right now.
Old Mar 4, 2010 | 02:25 PM
Etype R's Avatar
Yup thats a lockright style, should work fine. You can't really unlock them without installing them, and using the tires to spin one side.
Old Mar 4, 2010 | 02:46 PM
  #25
seanmearse's Avatar
So, looking at the pics, is it disengaged?
Old Mar 4, 2010 | 02:50 PM
  #26
85TurboRunner's Avatar
I don't think you can tell whether its engaged from a picture, but it should be since it needs the weight of the vehicle to unlock it.
Old Mar 4, 2010 | 04:13 PM
  #27
Etype R's Avatar
Its engaged, it only opens up when the right forces are applied to it. When driving with one, if you let off the gas or press in the clutch in a turn it will unlock. But if you hammer down on the throttle into a turn, it will remain locked.
Old Mar 4, 2010 | 08:10 PM
  #28
seanmearse's Avatar
Well thats good to know, so, jonny, we got a deal? lol. I just want my truck back on the road!
Old Mar 4, 2010 | 08:16 PM
  #29
dropzone's Avatar
Fossilized
nice score..either a lock right or aussie...basically the same thing
Old Mar 4, 2010 | 08:33 PM
  #30
seanmearse's Avatar
i know, but have to trade it to get the 4runner going again, aint got the money to regear it right now.
Old Mar 5, 2010 | 07:49 AM
  #31
JonnyBoy's Avatar
Yeah, we got a deal. How bout I trade the open 4.10 and the knuckle service seals/gaskets for it? When I get down there today we should make absolutely sure your rear is 4.10 and not 4.30 or somethin though.
Old Mar 5, 2010 | 08:15 AM
  #32
seanmearse's Avatar
yeah, here is an easy test, lets get that third in, and put her up in 4X4, see what happens.
Old Mar 5, 2010 | 09:14 AM
  #33
Etype R's Avatar
Better test... with the truck in neutral lift one of the rear tires in the air. Mark the pinion flange and the diff housing for a starting point, and chalk a vertical line on the tire. Now spin the tire 2 full revolutions while counting how many times the drive shaft turns. You will be able to tell if it was just over 4, 4.3, 4.5 ect.
Old Mar 5, 2010 | 09:40 AM
  #34
JonnyBoy's Avatar
Only if you floor it in 4 lo on dry cement.
Old Mar 5, 2010 | 09:43 AM
  #35
JonnyBoy's Avatar
Yeah, he did that but only 1 revolution of the tire and got almost exactly 2 turns of the driveshaft. We just gotta do it again 2 revs cause of the open diff.
Old Mar 5, 2010 | 01:13 PM
  #36
Dingman's Avatar
Originally Posted by seanmearse
WOW, you guys were right, lined up the flat spots, slipped right out. Took all of litterally 5 minutes. See, I should have posted up on here before taking the two hours to try and figure it out, once again, YT comes through! Thanks again Toyo and E TypeR.
Doh! Videos are good too, so it's always worth a shot to search youtube.
http://www.youtube.com/watch?v=duvs-xbKrW0
Old Mar 5, 2010 | 01:35 PM
  #37
seanmearse's Avatar
Already got them out, but thanks for the video. Got one side rebuilt, all back together, would have had the passenger side done by now, BUT, the trunion bearings came out in pieces, and left the inners stuck on the end caps, so those are at the machine shop for removal, heading back out to finish cleaning parts and pull the 3rd out of the 83.
Old Mar 5, 2010 | 07:35 PM
  #38
seanmearse's Avatar
IT'S DONE!!! Finally finished and test drove her, no leaks and steers like a dream now. Thanks to everyone who helped!
Old Mar 5, 2010 | 07:37 PM
  #39
seanmearse's Avatar
Also, the 4X4 works great now, too.
Liadrin
Apr 25, 2022 02:54 PM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
