Speedi-Sleeve for Rear Axles..?
Hi All,
I am getting fed up of replacing 3rd Gen Rear Axle oil seals, my 4Runner is a '96 but only has 48K miles on it. I have replaced the right oil seal 4 times and the left 6 times. I even had new axels and bearings put in about 2 years ago... Does any one know if there is a Speedi-Sleeve that I can use on these shafts. I doubt the shafts are worn but figure if the Speedi-Sleeve could make them just that little bit larger then the seal might have a better chance of keeping the oil in.
Thanks,
Thanks,
I don't think the breather is plugged since it is a big 'ol fuel filter on the end of a sturdy type-A1 marine hose tucked up under the fuel filler - but it's a worth a check...
Might they last 8-16 months (guestimating, based on how many I have changed in the past 5 years), or would they go straight away if something was bent..?
Abused did cross my mind also, I drive all of 6 minutes to and 6 from work every day and since my drive time is so short I try to get all my driving kicks in in that short space of time, routinely I will break a tire loose either accelerating or decelerating
I love my Sports Truck
So I take it no one has heard of or used a Speedi-Sleeve on the runner..? Maybe I need to spend a little mote time with my good freind
kirkrunner
Jul 27, 2015 07:59 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
