Speedi-Sleeve for Rear Axles..?
Old Oct 22, 2009 | 07:54 PM
NJ's Avatar
NJ
Hi All,
I am getting fed up of replacing 3rd Gen Rear Axle oil seals, my 4Runner is a '96 but only has 48K miles on it. I have replaced the right oil seal 4 times and the left 6 times. I even had new axels and bearings put in about 2 years ago... Does any one know if there is a Speedi-Sleeve that I can use on these shafts. I doubt the shafts are worn but figure if the Speedi-Sleeve could make them just that little bit larger then the seal might have a better chance of keeping the oil in.
Thanks,
Old Oct 23, 2009 | 03:27 AM
crolison's Avatar
Sure you don't have a bent axle or bent axle housing?
Old Oct 23, 2009 | 03:33 AM
jrohland's Avatar
Take a breath
Or perhaps the breather is plugged.
jrohland
Old Oct 23, 2009 | 03:41 AM
dropzone's Avatar
Fossilized
abused maybe...
jrohland
bingo
edit: OP's sig says he has a rear diff breather...improper seal..
Old Oct 23, 2009 | 09:53 AM
akaphilly's Avatar
if the breather is clogged. it will cause the seals to blow. even if its extended. very common.
Old Oct 23, 2009 | 10:05 AM
85excab's Avatar
and marlin crawler makes heavyduty rear axle seals
Old Oct 23, 2009 | 10:17 AM
ESQ's Avatar
ESQ
Marlin crawler doesn't make one for the ABS axles. I wish they did.
Old Oct 25, 2009 | 06:06 PM
NJ's Avatar
NJ
I don't think the breather is plugged since it is a big 'ol fuel filter on the end of a sturdy type-A1 marine hose tucked up under the fuel filler - but it's a worth a check...
Might they last 8-16 months (guestimating, based on how many I have changed in the past 5 years), or would they go straight away if something was bent..?
Originally Posted by ocdropzone
abused maybe...
Abused did cross my mind also, I drive all of 6 minutes to and 6 from work every day and since my drive time is so short I try to get all my driving kicks in in that short space of time, routinely I will break a tire loose either accelerating or decelerating I love my Sports Truck
So I take it no one has heard of or used a Speedi-Sleeve on the runner..? Maybe I need to spend a little mote time with my good freind
okamikai
Apr 30, 2018 10:19 PM
kirkrunner
Jul 27, 2015 07:59 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
